Originally posted by saaya
hmmmm i pretty much have the same history nostra, the 8rda+ a bunch of nf7-s 2.0 boards and finally the a7n8x deluxe rev2.0 i really really love this board and im not sure if i would get another one or a dfi if this one should die... i didnt know about the high vcore/fsb/vdimm probs of the dfi boards... i think i will keep recommending the a7n8x then. a7n8x has the best and most stable voltage circuicity ive seen on a mobo. great mosfets and capacitors! even with 2.15v vcore, 2.2v vdd and 3.8vdimm with modded rails the mosfets only get slightly warm under heavvy load, not like the smoking mosfets on abit and epox boards... :D
the onboard stuff gets buggy above 240fsb no matter what vdd though and stops working above 260fsb. what good is 280fsb+ if you cant use high vcore and vdimm.... my board lets me bench at "only" 255fsb max but i can use any vcore and vdimm i want...
I thought you were aircooled with a duron @ 2.2ghz?? But now I see this...2.15v vcore, 2.2v vdd and 3.8vdimm ...that can't be for your aircooled duron that does 2.2ghz? :)
