second try
4770K@ 4800HT on 1,36VCore LOAD / TeamX 2666CL11-13-13-35 1T - 2933CL12-14-14-35 2T@ 1.75
http://i.imgur.com/3My38oi.png
second try
Hey bud. Got mine built and windows installed last night but no time to overclock. Just went into bios, set to 46x, 1.26vcore 2600Mhz mem and everything ran great. Will now start pushing it!
Maximus 6 Gene Bios 0711
Intel 4770K @ 4600Mhz 1.26vcore
TeamGroup 2x4GB 2400Mhz @ 2600Mhz 1.66v
2 x OCZ Vertex4 128GB RAID0
Asus GTX 670 DCUII
Corsair AX1200
Custom water loop on CPU
http://i580.photobucket.com/albums/s...psf2fea650.jpg
Thanks Owi, Dumo and Peter for telling me the 125 strap lol i was sad i couldnt boot at 3000mem
now i passed SPI32 at 3000CL12 lol
running
http://i.imgur.com/pG4RT9k.png
finished
http://i.imgur.com/DZMxP6W.png
Nice job!
Is the strap an Asus thing only?
Nice results Andres :D Keep it up man...Gonna have
Good work Sergio, keep pushing that amazing board!
Cheers
4770K@ 4750HT on 1,36VCore LOAD / TeamX 2666CL11-13-13-35 1T - 3000CL12-14-14-35 1T@ 1.75 yes 1T !!! i luv it !!!
http://i.imgur.com/duR2row.png
as i have EIST and C1E i let runing SPI at background to show CPU speed as it goes instant down
hope you guys like it
cheers !!!
Sergio
The real proof that my ADSL modem heats more than Haswell
LOL !!! Elvis is sleeping over it
http://i.imgur.com/j3YmZh8.jpg
4770K@ 4900HT on 1,424VCore LOAD / TeamX 2666CL11-13-13-35 1T - 2933CL12-14-14-35 1T@ 1.75
this is the hard part where vcore starts to be exponential, sweet spot for this chip is 4800HT on 1,35
http://i.imgur.com/uNUKUQh.png
Hey bud here's a quick screenshot. Working on finding my 24/7 config. Havent tested max mem yet but probably nothing crazy as this kit would only do 2800Mhz on my 3770K.
http://i580.photobucket.com/albums/s...ps89b9fbfc.jpg
THE BEST ACHIEVEMENT of the WEEKEND
4770K@ 4750HT on 1,36VCore LOAD / TridentX CFR 2800CL11-13-13-35 1T - 3250CL12-15-15-42 2T@ 1.725
http://i.imgur.com/LjUi0oL.png
Did you download the latest version from Intel? There should be a "Benchmarking" button on the left on Ivy Bridge and Haswell setups, take a look at the first two pictures in this thread.
i submited and have N/A points so when i submited
http://i.imgur.com/cuE6Jnj.jpg
I saw your 3770K submission, so it doesn't work on Haswell?
some 3000CL11 MFR
http://i.imgur.com/Yj8WFPp.png
Awsome set up my friend , nicely done ! Nice Numbers Bro. Like Oliver used to say keep pushing :D
Ok Guys...last night i delided my 4770K i must admit that the hand method i used for 9 IVY its a little hard on Haswell but worked either way chip is bit smaller my hands are big so that was the deal...
Before delid
*I couldnt boot 5GHz no matter volts WONT POST
*My TeamX 2666CL11 wont boot 3250 WONT POST not even 3050
*Tested till 4800 hyperpi was impossible it rebooted no mater the volts
After delid
I can do whatever i want, boot 5GHz, temps decreased 29C, my TeamX got to 3250 easy, i can run Hyperpi at 4800 32M stable, etc etc
IM VERY HAPPY I DID THIS
some pics
http://i.imgur.com/CtnOCpP.jpg
http://i.imgur.com/8njfB9j.jpg
http://i.imgur.com/bBEvBPS.jpg
The proof
I couldnt even take a screenshot of hyperpi runing at 4M !!! temps where to the 84C and i saw 90C then rebooted, i was able to take this pic
http://i.imgur.com/AjG4cEx.jpg
after delid...
it also passes 32M
http://i.imgur.com/faHox05.jpg
TeamX 2666CL11@ 3250CL13
http://i.imgur.com/gS9Ju8D.png
5GHz HT
http://i.imgur.com/4kntz8e.png
Great results...I wouldn't delid if I had one now, had bad experiences with Ivy xD
