Dust filters there will be!
Bonjour once again from Europe!
Kudos for identifying these pics:
http://img.photobucket.com/albums/v3...ps8a09e0a6.jpg
http://img.photobucket.com/albums/v3...ps0de8b6e2.jpg
Lots of people ask me where I get my inspiration, and it comes from a lot of directions--particularly interests in materials (plastic, metal, wood). But also from all kinds of other things. For example, in the museum pic above, I love the victorian style small window panes, I just may have to incorporate that into a mod someday.
Back to the modding...
I had just finished painting all my pieces, so its time to start assembly.
First I set up my 2 large side panels, and attached the wing shelves:
http://img.photobucket.com/albums/v3...ps2ba4507c.jpg
Next I added the cross boards and got this unit upright:
http://img.photobucket.com/albums/v3...psa0d81645.jpg
Got the table top on and various brackets:
http://img.photobucket.com/albums/v3...ps73ffa1de.jpg
Made sure the motherboard tray still fit and functioned:
http://img.photobucket.com/albums/v3...ps51c520f6.jpg
Added the front doors:
http://img.photobucket.com/albums/v3...psc8e6f37d.jpg
http://img.photobucket.com/albums/v3...ps28c8ce4f.jpg
And a little something somewhat hidden. I needed to fill in this portion of the dado cut on the underside of the table top (eventually I’m going to add edge trim to the table top), so I used some leftover trimmed plywood. I think edge cut plywood looks pretty neat when finished off nicely:
http://img.photobucket.com/albums/v3...ps1ec51ea1.jpg
Okay, let’s finalize this structure.
I used a combo of glue, screws, and pin nails to make it make this cabinet furniture strong:
http://img.photobucket.com/albums/v3...pscccade58.jpg
http://img.photobucket.com/albums/v3...psd7d24507.jpg
You could dance on top of this case.
Put the final touches on my backer panel:
http://img.photobucket.com/albums/v3...ps98edf389.jpg
A hole for the cables to exit, and 2 coat hangers (2x $4) to wrap the cables on.
Mounted my fan panels:
http://img.photobucket.com/albums/v3...psd4d3b133.jpg
And mounted my fans:
http://img.photobucket.com/albums/v3...ps05255f06.jpg
http://img.photobucket.com/albums/v3...ps923b0a27.jpg
Note, on my triple intakes, I’ve got these mesh dust filters. They do a good job and are easy to clean off as a shop-vac is never far away.
Next, to control the fans, I’ve got a Scythe fan controller, which I put together a simple mounting bracket:
http://img.photobucket.com/albums/v3...psf15774f1.jpg
http://img.photobucket.com/albums/v3...ps8cc8b658.jpg
Finally, I carefully routed and mounted all my cables to allow the system tray to easily roll out and/or fully remove.
http://img.photobucket.com/albums/v3...psdc503e07.jpg
To completely remove the system tray, these are my steps:
1) From the backside disengage the monitor connection, and i/o cables (USB, audio).
2) From the front side, there are 3 cables to disengage, which are highlighted:
1. PSU cable
2. Cable to power the fan controller
3. Switch panel cables
http://img.photobucket.com/albums/v3...ps4dabdc5e.jpg
After disconnecting these cables, the whole computer system tray can slide out and even be completely removed.
Next it was time to mount the cabinet to the truck:
http://img.photobucket.com/albums/v3...psd6188f6b.jpg
http://img.photobucket.com/albums/v3...pscc4d016f.jpg
Four deck screws thru the bottom of the panel.
And now that we’re mobile, I took the project outside for some nice weather:
http://img.photobucket.com/albums/v3...ps64264094.jpg
Finished the trim on the table top:
http://img.photobucket.com/albums/v3...pscc962dbd.jpg
Added the monitor stand:
http://img.photobucket.com/albums/v3...ps774aa350.jpg
Started running my cabling. Here you can see I wrapped my power and ethernet cords on the coat hangers:
http://img.photobucket.com/albums/v3...pse05c2918.jpg
More cables back here:
http://img.photobucket.com/albums/v3...ps0cadd350.jpg
Finally mounted a lot of my items with Command strips. I like using these as they’ve got strong grip, yet are still easy to remove:
http://img.photobucket.com/albums/v3...ps36543fe4.jpg
Command strip the USB hub:
http://img.photobucket.com/albums/v3...ps6a487d36.jpg
Stick on the speakers:
http://img.photobucket.com/albums/v3...psca474505.jpg
And there you have it! My completed project:
http://img.photobucket.com/albums/v3...psca0695eb.jpg
Did run into a little and somewhat time-consuming delay. I could not for the life of my get 2 sticks of 4gb to work on this motherboard. Played with all the timings and voltages. I got 2x1gb to work fine, but opted for 1x4gb.
As usual, I will be taking a big set of final pictures, so give me a little time to produce and edit...
Nice result & looks :up:. Only i have a bit suspicions about white surface being a bit too easily dirtyable, witch pc/cabinet being used in workshop and such.
BTW, why not bolt/hardfix speakers to surfaces or walls of cabinet? +maybe hide cables of speakers to go within or behind walls ..
The surface is melamine, which is pretty durable and cleanable. And inexpensive and available. As for surface dust, I will take care of it the old fashion way--clean it! Not like a different colored surface will have less dust, just hide it a little better?
My experience with computer speakers is that give up the ghost every now and then. My thought is that this cabinet will probably outlast the speakers, which is why I'm hesitant to permanently mount them.
Regarding speaker cables, actually I did create some routing tunnels:
http://img.photobucket.com/albums/v3...psce468aee.jpg
Cabinet PC Completed
I’m going to include a very quick summary of the build, for people who might be joining in and don’t want to work their way thru the whole log.
Cabinet PC was my attempt to put together a quick scratch built mod with the following ideas in mind:
1) Based on a simple box cabinet
2) Inexpensive
3) Houses a system on a accessible slide-out try
4) Large worktop
5) Function as a portable PC with music/speakers, primarily for my modding/woodworking shop.
Here were my intial design sketches:
http://img.photobucket.com/albums/v3...pse45b2f89.jpg
http://img.photobucket.com/albums/v3...ps54279243.jpg
Fabrication proceeded with standard hardware stuff like plywood, melamine tops, kitchen drawer slides, hinges, etc.
http://img.photobucket.com/albums/v3...ps6c3c5b2f.jpg
http://img.photobucket.com/albums/v3...ps5160daca.jpg
http://img.photobucket.com/albums/v3...ps2a8bd001.jpg
Lots of painting and staining:
http://img.photobucket.com/albums/v3...ps074212bb.jpg
And final assembly:
http://img.photobucket.com/albums/v3...ps5879dac5.jpg
And here’s my baby!
http://img.photobucket.com/albums/v3...psb9ac2316.jpg
Double cabinet--lower compartment for storage, upper for the PC.
Wing shelves for the speakers.
Large worktop.
All on a rolling chassis.
Closer look at my desktop:
http://img.photobucket.com/albums/v3...ps30f671b6.jpg
Large work area made of white melamine. Monitor stand holds the monitor and has under-storage for the keyboard. Got a mouse, USB hub, and speaker controls.
The monitor is bolted down to withstand the vibrations of this unit on the go.
http://img.photobucket.com/albums/v3...psb1c1c7a3.jpg
Here I’ve got my switching panel.
Domed button = Power on.
Flat button = Reset.
Blue LED = Power.
Green LED = HDD activity.
The USB hub is a Rosewill 7 port.
Moving down to under the worktop, I’ve got wing shelves that hold the speakers.
http://img.photobucket.com/albums/v3...ps369fbe7c.jpg
I’ve got a triple 120mm fan intake on this side of the upper box of the cabinet, which houses the PC components. The fans are all on a fan controller, keeping them pretty quiet. They also all have critical dust filters, as this whole system will be spending most of its time in my modding/woodworking shop.
For my speakers, I’ve got a Logitech X240 2.1 system.
http://img.photobucket.com/albums/v3...ps418c73ce.jpg
On the other side, at this level, are the 2 120mm fan exhausts.
3 fan intakes, 2 exhausts--I’m try to keep positive pressure as another measure of dust control.
Here you can really see the basic cabinet box base for the project:
http://img.photobucket.com/albums/v3...psa8cb5245.jpg
The structure of it all is a box of ?” plywood. There are 2 large side panels, a bottom, a cross shelf, and a backer panel. All the joints are dado/rabbets, glued and nailed, meaning this thing is strong.
Also, the cabinet is mounted to a rolling chasis, which is really just a square of 2x4, stained, and with wheels. The front wheels lock, and the rear wheels turn.
Open the doors and now you can see the internal storage.
http://img.photobucket.com/albums/v3...ps492779b6.jpg
As you can see, the upper box holds my system components.
The larger lower box has shelving, and the UPS, (which truly makes this a mobile workstation).
To open the doors, I used a push-to-open latch, a system I’ve used before on many mods (and so already had the latches sitting on a shelf).
Video:
http://img.photobucket.com/albums/v3...ps3194a3d2.jpg
(Click to Play)
The upper box is an enclosed unit containing my PC components:
http://img.photobucket.com/albums/v3...ps723cac28.jpg
The system is mounted on a single tray, that slides out on kitchen drawer sliders. In fact, just like a kitchen drawer, it can be easily completely removed.
There is a bit of a procedure to do so, however, due to all the cables and whatnot. But it actually only takes a few seconds--in fact here it is in video.
Step 1
Access the back hatch and disconnect all the i/o cables (monitor cable, USB ports, ethernet port, audio):
(Video)
http://img.photobucket.com/albums/v3...ps48f6e279.jpg
(Click to Play)
Step 2
Open the front cabinet door, and disconnect 3 cables:
1) 4 pin molex to fan controller
2) PSU cable
3) Switch cables (power-on, reset, power LED, HDD activity LED)
Step 3
Slide out tray, and remove
(Video)
http://img.photobucket.com/albums/v3...ps2b127b65.jpg
(Click to Play)
Here is the system I’ve got mounted, all of which were parts scavenged from previous builds:
http://img.photobucket.com/albums/v3...ps6d6339db.jpg
Core 2 Duo e8600
Gigabyte EP45 UD3R
4gb G.skill RAM
Thermalright AXP-140
Corsair HX620 psu
Kingston 128gb SSD
Asus AX550
Let’s push around to the backside
http://img.photobucket.com/albums/v3...ps8b5e8976.jpg
Got cable storage for power to the UPS and ethernet.
The backside hatch opens (push-to-open latch, again).
http://img.photobucket.com/albums/v3...psf8dbe5f6.jpg
Fair number of cables, tried my best to keep it clean.
Also you can see the fan controller.
No wait!
Build a rolling PC station?
Got to take it for a ride!
http://img.photobucket.com/albums/v3...pse0182acb.jpg
http://img.photobucket.com/albums/v3...psc197f845.jpg
http://img.photobucket.com/albums/v3...ps9eebe52a.jpg
http://img.photobucket.com/albums/v3...ps399183ac.jpg
http://img.photobucket.com/albums/v3...ps41f788d1.jpg
http://img.photobucket.com/albums/v3...ps5b435c08.jpg
http://img.photobucket.com/albums/v3...ps4ab88084.jpg
http://img.photobucket.com/albums/v3...ps79f2bb18.jpg
http://img.photobucket.com/albums/v3...ps83a8947b.jpg
http://img.photobucket.com/albums/v3...ps50ee330b.jpg
http://img.photobucket.com/albums/v3...ps096b8e49.jpg
There you have it.
In case you were curious, with my old UPS APC, I was able to stream Pandora with the speakers on loud for about 1 hour.
Lets get to some lists:
Items I already had:
System components: Core 2 Duo e8600, Gigabyte EP45 UD3R, 4gb G.skill RAM, Thermalright AXP-140, Corsair HX620 psu, Kingston 128gb SSD, Asus AX550, APC UPS, fans, fan controller, mouse, keyboard, USB hub, monitor, Logitech x250 2.1 speakers, switch panel, Edimax USB wireless unit. (~$700)
Screws/nails (~$10)
Plastic fan mount panels + dust filters (~$30)
System tray bracketry ($15)
Melamine stock ($30)
Item purchased:
Stock plywood
3/4” Main structure ($45)
1/2” system tray, floating shelf, shelf pins ($20)
1/4” backer panel ($10)
2x4 lumber ($10)
Caster wheels ($10)
Hinges ($18)
Cable management ($15)
Stain and polyurethane ($30)
Drawer slides ($15)
Push to open latches (~$7)
Cable hooks ($8)
I think that’s about it.
So started with about $785 in components and spent about $188.
And took me about 3 months of work.
No sponsors, but my usual sources:
mcmaster.com
rockler.com
home depot
lowe’s
delvie’s plastics
performance-pcs
frozencpu
jab-tech
Special thanks to my wife, and everyone at ocforums, theraptorpit, and xtremesys forums.
Navig
http://img.photobucket.com/albums/v3...psea5ed8aa.jpg
*** I've just posted my entire Complete Project, for a quick link to the start of the Completed Section, click --> Here <-- ***
I wonder if some mod is possible with big capacity auto accumulator batteries in cabinet for lengthy socket&wire free action :). May require some PSU mod though.
