Time for some photos!
http://img694.imageshack.us/img694/7977/fansa.jpg
This is the card.
Since my motherboard has only PCI-E x8 slots, I had put a PCI-E x8 to x16 adaptor/riser. It wasn't necessary to remove it from the card, so I left it there.
http://img854.imageshack.us/img854/6714/portsbh.jpg
Front connectors: DVI, HDMI, VGA.
http://img145.imageshack.us/img145/5310/backmh.jpg
Only one 6-pin power supply connector.
http://img824.imageshack.us/img824/3500/backpcbl.jpg
Back of the PCB. The cooler is secured with only 4 screws around the GPU. By the way, I think the HDMI connector is just for show, I don't see any traces for it on the PCB. I connected a monitor with an HDMI cable to check, and it didn't work. Only the DVI & VGA connectors work.
Let's see some more angles.
http://img402.imageshack.us/img402/4341/downgm.jpg
http://img138.imageshack.us/img138/8338/topdf.jpg
The cooler/heatsink is attached only on the GPU, the ram chips and everything else have no heatsink at all. I hope the air from the fans can cool them sufficiently.
As you can see the fans are wired together, they used heat-shrink tubes to cover the wires. I don't like how it looks, seems unprofessional.
Finally! Let's remove the cooler!
http://img208.imageshack.us/img208/9...dandcooler.jpg
Some grey thermal paste was used, the heatsink was attached only on the GPU, everything else had no heatsink at all. I wonder if the card can survive like that. Well, I guess I won't be using my Phobya thermal pads after all.
http://img19.imageshack.us/img19/1029/coolerback.jpg
A closer look of the back of the cooler.
http://img209.imageshack.us/img209/5532/rams.jpg
The RAM chips are Hynix, H5RS1H23MFR-N0C.
http://img855.imageshack.us/img855/4092/gpuo.jpg
And last but not least, the GPU!
It has the following written on it:
NVIDIA
39N3FA 0839B1
A TAIWAN
PB0920.03V
What kind of GPU is this? Does anybody know?
The cloth I used to clean the GPU was terrible, definitely not lint-free. I cleaned it up better afterwards.
For now, I have reattached the cooler and put the card back in the pc (this is the only card I currently have, for it).
The idle temperature with the stock thermal paste was 53 Celsius, and now with the Arctic Ceramique 2 is 50 Celsius, not a very big difference, I guess the stock thermal paste wasn't very bad.
