Thanks for the reply FlanK3r :up:
I was reading the other day in the amd section about ht.
In there it said something about the fpu it's self supporting ht of some sort, I don't know if that is a mix up or not.
I think I may wait it out one more gen and then upgrade my board and cpu at the same time.
I'm sure this x6 1090t of mine will hold out until then :).
The newer gen boards and cpu's look like alot of fun to clock though.
One thing I'm curious about, the win8 boot option in the bios.
Is it alot faster?, win8 on my board the ch4 formula doesn't really boot win8 any faster then win7.
Then again I wonder if enabling that option will screw up loading dos/linux and win7.
I thought about getting a new setup, plus a new cpu cooler, but I'm holding off on it.
I wouldn't beable to fit a 2x120mm rad in my case anyways.
At moment the only thing I'm looking at is blue ray burners.
Here's some small ?'s for ya, maybe you can answer then or maybe not :).
How far will the cpu clock on stock voltages?
What is the limit in the bios for the pcie clock? (I know most don't mess with but I do and I'm curious :) ).
