Can you post what temperatures you are getting as I am planning a very similar setup ... would be much appreciated.
Temps are really going to depend on a variety of factors if you are water cooling. What this case is great at is creating a wind tunnel from front to back. There are two 140mm fans up front, and as long as you keep you cables tidy, they will blow a lot of outside over your setup. That changes if you mod the front to stick a 2x140 rad there. Or mod the bottom or top for rad placement. But as far as a stock air cooling case there aren't many better, and none that look as good imo
