Summarized OC' guide
http://kingpincooling.com/forum/show...1&postcount=29
This is my first micro board. This thing seems to be pretty awesome, having fun testing memory for now.
Awesome run there OC:up:
Info about LB...
http://img7.imageshack.us/img7/6181/screenshot192u.jpg
Latency Boundary:
Simply put you can set the biggest value of 14 first to find the limitation of your DRAM/CPU after which you can try setting 6 or 9 (which are good compromises between stability and performance) if you think your setup is able to run it.
LB is tied to secondary and tertiary timings
Setting 1 if your ram can keep up..
http://img404.imageshack.us/img404/3...enshot190b.jpg
Got this with samsung 30nm ram..
http://img42.imageshack.us/img42/467...enshot072i.jpg
BBSE..
http://img51.imageshack.us/img51/802...nshot179rr.jpg
Thanks Dumo!
The board clocks extremely well. Can boot at 2800mhz+ but my memory has reached its limits, so 2600-2666 is about tops for now.
G.Skill RipjawsZ 2133 16gb kit @2600
whats the diff between ripjaws z and ripjaws x?
^ Im not really sure, these are a quad ch. kit, I thought the X were dual ch.?
G.Skill 8gb 2800c11.
these are some serious clocks. looking amazing.
http://i.imgur.com/mFfwV.png
not sure why 6-9-6/7-9-7 do not work, but bclk oc is very nice.
Its gonna be awesome runs om Zan:up:
air...
http://img72.imageshack.us/img72/979...enshot194n.jpg
i cant believe the ETA on these boards is 30th april here in Aust.
reading these results is literally painful.
Yeah it sux, but they look great, I cant wait to get my hands on one. I might even grab two, one for my water gamer/benching rig and one for dedicated single stage testing/benching.
Good times ahead.
0805 still the latest BIOS for this right?
EDIT - Nevermind, looks like 0880 is the latest now.
Is the Asus t- topology built into these boards? Or is it for later gen z77?
I'm keen on a formula too depending on its price vs the sniper3
There is so much tweaking that can be done on this board, I can just keep playing around with memory without getting bored.
I put the Samsung 30nm kit back in to try 2600 again. After doing a little reading at KP Forums about the board, I was able to get them benchable at 2600 10-12-12 with Latency Boundary 6, by adjusting the Transmitter, and Receiver Slew. Need to play around with the 2 settings a little, but this seemed to work with this kit. With my GSkill's, the best I can do is LB 8, so the 32m time was a bit slower.
