You are a fantastic friend , only another question can you link me please wich kit 4x8 i need ?
For you it is a good for me ?
Vengeance? Memory ? 32GB 1866MHz CL9 DDR3 (CMZ32GX3M4A1866C9)
Carmine
Look for X79 memory kits (quad channel). May I ask, why do you need 32GB? Is 16GB not enough?
IF you actually need 32GB for R4E1 then buy a 32GB kit for X79. If you only need 16GB on the R4E then buy a 16GB kit for X79.
raja sorry help please , why aircool on chispet dont work ?
I have a bios 4102..it is a normal?
No idea what you mean there. Something is being lost in translation.
If it's the PCH cooler, yes it's normal, as PCH does not get very hot. Was originally designed for extra PCH SATA ports which Intel removed. You can possibly set it to on in UEFI fan control if you need to - depends on temp. But generally no need.
raja ..please help for overclock my 3930k ...for 4,5 ghz Power Limit ...(long duration power limit ) Set Auto or 255 ?
Leave on auto. Do not change.
Start with easy guide here:
http://rog.asus.com/forum/showthread...untry=&status=
