well.. got the damn thing running properly :D
Unfortunately i screwed up my 360 rad :mad: the screws i used turned out to be too long and when
fitting my new fans i accidentally overtightened the screws and punctured the rad :'(
so now i'm stuck using the rad i wanted to use for my GPU untill i get my new 360 rad.
Since i was already at i also ordered new tubing (1/2) and fittings. Don't really like the small tubes i got now.
I am guessing it will be a much faster build nex time.
On a side-note: i have to say i am a little disappointed with the temperatures. Under normal circumstances my Scythe Mugen rev B. performs equal.
Temps are idling at aroud 50degrees for both the wc as my previous air setup. Vcore=1.3 is this normal?
Anyways.. for those of you who helped me and are curious to see how it turned out i have also added some pictures.
https://lh6.googleusercontent.com/-k...2021.07.18.jpg
https://lh6.googleusercontent.com/-J...2021.08.31.jpg
https://lh6.googleusercontent.com/-r...2021.09.27.jpg
https://lh6.googleusercontent.com/-t...2021.10.27.jpg
Greetz
