Whoo hoo upgrade to a slower PI time! Oh wait I already have that with SB-E :)
It's a bit like when Core 2 was shrank from 65nm to 45nm, nothing big but still a little architecture optimization.
>10% IPC improvement in some tasks?
http://img440.imageshack.us/img440/6830/intelivy.png
No, mostly turbo I guess.
As usual from die-shrink "tock" at this point u can add the typical 4 ~ 10% IPC increase (around 15% in some special cases) but what is attractive is its performance/power consumption/overclocking. I pray it'll do like 5.5GHz @ 1.35v on an average sample and consume quite a bit less power than Sandy would do at like 5GHz 1.4v. This is just speculation but one can always hope right. :D
I like throwing my overclock speculation pre-launch so here's mine:
Worst sample: 5.3GHz @ ~1.35v
Average sample: 5.5GHz @ ~1.35v
Best sample: 5.7GHz @ 1.36~1.37v
i5-3750K / i7-3770K on good aircooling
For 24/7 I probably wouldn't use more volts than that on 22nm (with air/water at least).
There is a lot of work on the manufacturing end that needs to happen for this not to slip another quarter. Also the problems they are having, could lead to very wide ranges of potential across chips.
It really depends on how the '3D' transistor works ok, and the tweaks that are involved. In reality it is much more than just a normal shrink.
lol when i saw the title i kinda guess its from coolaler... that guy lives next to gigabyte, asus's headquarter or something, and has friends inside.
performance seem ok, for ES. more interested in how much more clock u can get out of it compare to SB.
This, hopefully coolaler can give us an early sneak peak, doubt it'll happen quite yet though, the launch is so far away.
EDIT: Funny how he got like 19s something at 2GHz but 14s something at 2.6GHz with a newer bios, seems like the bios helped quite a bit as well, such a clock doesn't usually result in such increase, so looks like bios optimization has a road to go still. :P
Don't know if it was already posted, but there are some interesting slides here:
http://hwbot.org/forum/showthread.php?t=34548
http://imup.se/i/JQo6oNv5Wf.jpg
that ipc boost seems a bit large...
http://www.xtremesystems.org/forums/...re-Goes-Mobile
If the above romours are true then people should get used to not seeing spectacular things from Intel anymore. Expect for spectacularly high prices!
Yea 17% sounds a little optimistic (and the first test probably is using AVX) but when isn't a score produced by the manufacturer itself always a bit higher than what average joe gets in the same test? I bet we are more likely to see maybe around 10% or so in those tests. But OMG @ the internal GPU performance increase... sounds like it might be able to play a few even newer games at lower res quite fine.
funnny when sb-e was pending everyone was screaming IVY IVY.
Now this leaks and said people are like "what I never said anything about ivy!"
Damn i5-3570K is my next CPU
