Thank you guys. Brainpower PCB, double sided, 4 chips per side. Corsair 3200LL and Mushkin 3200 LVL2. I think I'm able to break 350MHz pretty easy with one stick, but I will leave this possibility as a backup :D :D
As I tested more than 50pcs of BH memory, I can share few interesting facts:
- high binned sticks are mostly crap (<290MHz), nice clocks on low voltages (3.3v) but poor scaling and can't take much voltage.
- avoid single sided, double sided 4 chips per side are usually better.
- BH5 = BH6 in terms of overcloking. BH6 are generally weaker because of cheaper PCB.
- poor scaling with cold, don't expect to gain 50MHz just because of subzero.
- the rule of "good batch" or "good week" doesn't exist, I have 300MHz+ "crappy week" stick and <270MHz with "legendary magic numbers".
- there is extremely difficult to find a stick able to scale up to 4.0v or higher. I found only 3 of them.
I was just round the corner ;)
http://img267.imageshack.us/img267/4769/41115863.jpg
