Hi again! Nicely coming along, now! :)
- :up:
- We did not hardpipe it. Indeed it looks nice, but we found that there was some disadvantages puting both inlets in front regarding the layout of the waterloop;
We used theese parts for the rads;
6x bitspower 90 degree rotary fitting
4x bitspower 10mm G1/4
- 6x of your chosen fittings
- Some feet of tubeing.
Here is how we set it up;
Schematic seen from above, relative to the case. The extenders were used where the "purple tube" are. Perfect fit! That was also one of the reasons why we used 3/8 ID + 5/8 OD: There is limited space between the PSU holder.
Attachment 121227
Schematic 2, just showing parallel in duty.
Attachment 121230
Ask any questions! Im to tired to think, lol :D
- Raystorm is a good choice! Just saw a graph here the other day, and it showed that it has less restriction than the Supreme HF - that makes it the least restrictive of all the popular blocks on the market per date.
- CF 6970 is never wrong! :) Dont know about the custom backplate. I have seen many have tried it, but most of them failed. I hope you change that ;) To bad there is none pure white blocks for that 6970 series. What colour is the PCB?
Edit; Concidered this? I think the give 655/D5 a good look!
Bitspower MCP655 modified top:
Clicky 1. Comes in three varieties as single top, and some as dual top.
Bitspower MCP655 housing mod:
Clicky 2. Comes in Chrome, Black Sparkle and Matte Black (aka Black Diamond). Can only be used with Original top or Bitspower top.
