Speaking for myself as a user, and as a manufacturer of liquid cooling equipment, the best "extreme cooling" (other than mountain mods of course) case I have ever used (implying that its design should be be looked at) is the Cosmos S because:
- I can hang a dual radiator (MCR 220 Drive including pump and reservoir) without any but one tiny modification onto the hard drive cage, using its existing 120mm fan holes to fasten the rad, and simply pulling the HD cage couple of inches away from the front of the case, which provides ample space to install everything, and then all is left is to drill one hole on each of the side cage panels to install screws and lock the cage in place.
- I can hang a triple radiator (MCR 320 Drive including pump and reservoir) on the upper panel without any modifications at all.
I only speak from a Liquid Cooling standpoint, so I will leave other features to the comments of other users. Feel free to contact me at
gabe@swiftech.com if you need any further input :-)
