that's is not a real measurement though. the width of a transistor gate is not the same as the length and is changed depending on how faster the transistor needs to be. also, it's common to see larger than feature size transistors on a new process.
you might want to check out these numbers on more important measurements such as contacted gate pitch (minimum distance between two gates) or SRAM cell size.
http://www.realworldtech.com/page.cf...109003617&p=11
a smaller node does not mean faster. all kinds of effects explained by quantum physics that were previously negligible cause many problems at sub 90nm.
rushing to a new node won't provide faster performance especially considering just how much labor goes into their current physical designs. many of the circuits are fast because they are custom made to reach timings. i guess it's kind of like starting weightwatchers to get washboard abs but you sit on the couch and watch tv all day. you have to put some work into it. examples of this could be fermi or r600. they were on cutting edge nodes but sucked because of who made them.
