insane chip
insane chip
well-the benchmarking machines been down for about 2 hours.
I came to post some results, and eat.
I also ran out of Acetone earlier so I went to get more from target too.
soon I am gonna get back to it, but I wanna eat too ;)
Cool stuff Kunaak.
Also, props for not rubbing scores and etc in everyones faces at all opportune moments. ;)
Looks nice :D
I'm more intrested in the dry ice setup as I wana give it a go soon :p:
yep, thats the 550 you did for me mick.
I still thank you for that-cause thats one mod that I just couldn't get a idea of how to do it, with the pots already in the control panel.
Nice Work!
That sounds like one hell of a fun afternoon Kunaak...... very nice clocks too.....
VERY nice clocks. Any pics on how you used that dry ice. How much did you go through for all that benching, lol.
Very NICE, K.......
GREAT high speed benchies!!!
C
heres some of the actual set up.
1 more
and finally...
Nice scores. What were the card clocks on that latest run?
Also I dont blame you for not running insane vdimm. Killing a $270 3200+ is very different than frying a $750 fx :)
Also what kind of temps are you getting with the DI?
the details of this score can be found here.
http://service.futuremark.com/compare?2k1=7478872
just when I was starting to get the hang of what this videocard can do, I ran out of dry ice :(
oh well-$17 dollars for 14 hours of fun.
not bad, and everything lived just fine :D
thats very nice:)
Nice going man!
Why is that last 3d mark run not @ 242x12,5 like your first?
That would have got you some more marks i guess...
Your friend is one lucky sod... :D
Originally posted by MickeyMouse
wrong!!! yes they do make an fx51 asus nf3 ;)
K> that cpu looks to be beter than Opp's and toms' they both need 2v+ for 3.1ghz :)
Don't no!Quote:
na tom can get almost 3200mhz+ benchable so he has a big lead but your cpu looks for the voltage .25-.4v lower to be better overclocker.
I alwais going max or nearly max core volt. Thats no problem with the -112 C Cascade. Thats meen 2.080-2.112 volt.
Lately with the 64 bit OS where the FX gets extra hot, I tried to lover the volt in the 3096 32M bench and the 3120 WR bench.
If I lower the FSB to aprox 225 and only use 32 bit windows OS
then it can go 3107 on 1.79 Volt
But why? I like best to do max cooling max corevolt, se what I get, and work on the memtimings at highest FSB.:cool:
Can't you do higher FSB Kunaak?
BtW here you are:
http://service.futuremark.com/compare?c=475872_2
PCMark2002: 10411 / 14725 thats 3201 Mhz Mem 246 2-5-3-2
:toast:
Gotta Lova AMD Cpu's :)
I ran out of dry ice before I could really start the benchmarking with the 5900.
I can get more this weekend, but it's unlikely.
the place closes at 10 am on saturdays, and I usually don't go to sleep till 5 am on fridays...
I just wonder why;)Quote:
