Originally Posted by
Praz
Funny you should say that. I can run Prime using all memory for 8 hours and have Memtest for Windows fail within an hour. I wouldn't use 7.5GB memory size in Prime anyway with only 8GB of memory. Windows requires more memory then would be left so Prime will start swapping with the hard drive on this difference.
Normally I stay away from the pros and cons of stability testing. LinX or Prime, regardless how it is configured, I can pass and yet not make it through a 2 hour render in 3ds Max. But I don't tell others their testing is flawed. There is no test for 100% stability. Just an indication that the system is stable under a given set of circumstances.
