This is true, i used netflix on my ps3 during the entire outage. The netflix application upon starting prompted you to login to psn and if you said ok it would go ahead and fail the initial login, then it would bring up the main netflix screen and prompt you to login again, you select ok the login would fail and you could watch your movies just like normal.
