Any idea which ICs?
may be PSC X _ _ Series
Any idea which ICs?
chew i meant thats the highest speed i've seen on p67 especially on high cpu speed.
most ppl were doing 2322
just saying btw..
Chew, what is the voltage monitoring program your using in your screenshots?
Lets see aida thats the version I have a crack for, CPU-z is the version bundled with M4E? OS over a month old and was installed prior to pax east..........
Does it really matter? Do i have to do a youtube video to show that i'm booting this speed..........with the 2133 rams.
Whoever really honestly thinks i'm using 1600 9-9-9 specced stuff, you can't be f(l)ucking serious...........:shakes: 9-9-9 1600 doing 2300 8-10-8 at reasonable volts? Ok............
It's all good, youtube coming anyway, the best part about people who try to discredit others is when the proof is posted they suceeded in just discrediting themselves ;)
I think I got all the requests.......
Data and time set check
Newest cpu-z check
Latest Aida check
TRFC pushed harder (72) check
Make you tube check
Here's 2 shots to go along with the you tube........http://www.youtube.com/watch?v=bau_ID5QfHo
I was bored so I clocked it higher to since i hate doing same :banana::banana::banana::banana: twice......
I think it's Elpida.
http://img193.imageshack.us/img193/8421/dsc6952l.jpg
@ chew*
:clap: show all the naysayers wuts up
i think they were asking and not questioning...
1176 mhz is godly ..nice work brian
Last test cas 8, jacked the subs all the way in, not really worth much, 8-10-8 or 8-9-8 no matter the speed really just doesn't have what it takes to be competitive.
Really need times in the 5:56 range untuned on win 7 to be worth running a tuned run in XP.
Moving on to Cas 7 now.
C7 prime results updated page 1.......here's some other stuff i tested just for kicks.
Looks like 8-9-8 1176 trades blows with 7-10-7 at the same speeds.
I tossed a 7-9-6 in there at 2300 for kicks which is actually a tad faster.
What kind of juice does it take for that 7-9-6-20? I may give that one a shot.
Awesome frequencies chew. Still wanna see CL6 though :D
Confirmed, mine still have original branding:
http://elmor.se/wp-content/uploads/2011/03/bbse1.jpg
Yah no problem elmor, I need to swap boards though, this m4e has some weird issue with vdimm over like 1.76v.
Happens to me with hypers to and I know its not the cpu.
Maybe i'll try the pro or I have the b3 m4e arriving in a day or so.
Think I was at max volts I can use on my board Ron, 1.768.
I will give cl6 a try now in prime see how far I can go with my voltage wall.
That seems odd. I can boot right up at 1.8+ on the pro :shrug:
Keep hitting post code 58 or 45 when high vdimm, I did try via bclk and voltage in windows but i was going for retarded settings, all sucked in subs and 2300+ 6-8-6. It's just locked the screen with turbo-v.
Gonna try the 1298 bios now that I worked on maybe that will fix some issues, this is the bios I debugged for 1298.
Yah I reported that playing with bios's seems that issue is adressed in bios 1302, can boot 1.85v if i like now not that it makes a difference.
This particular set is dated Dec 2010, It's really not that stellar C6 wise, most likely luck of the draw for c6 operation. Even with slacked subs 2133 6-9-6 isn't possible.
Out of curiosity I plugged in another set of gskills i reviewed quite some time ago and they did 6-9-6 no issues........No love for this 8-9-8 kit and c6 though.
I would reccomend for most users just to bench 32m 7-9-6 seems even a rather bad set can do that well with decent performance.
for me 8-9-8-20 has given some of the best times
thanks msimax
http://i52.tinypic.com/9jkrpt.png
Let me template it for you.
In aida it will be top to bottom
7-9-6-20-72-1-4-8-4-4-16-8 and that data drive timing next to TWCL in bios 3.
Might be able to suck some of those in more depending on how high your pushing, obviiusly less than 2300 you can tighten up a tad more.
Start with around 1.76v for 2133 try it there and work your way up.
My 2300 run that I did earlier I would project probably 5:54-5:53's in that ballpark tuned in XP on that chip you have around 6:01-6:00
