ok, I can next week try PRIME 95 with 2000 MHz RAM. I tested only with my gold 1090T PRIME...hehe, great chip 1.3V and 3950 MHz stable at aircooling:up:
http://img683.imageshack.us/img683/5...3954mhz277.png
I dont think BeepBeep that all back pins soldered prove that it will work with the mainboard in question.They still could not connect all of them internally.
But i think asus press release is solid evidence in itself that it could be done and Am3+ isnt needed at least for initial batch of BD`s.
Future "AM3+" cpus could only really mean BD, as even if AMD will introduce some ageing PHII`s after AM3+ launch ,theyre still going to be marketed as AM3.
As for peeps wondering about 7xx series chipset compatibility.Asus announced new am3+ compatible boards based on 7 series already :P.
What is weird tho, is the different keying, its an easy way to force users to new socket.BUT, asus`s compatibility claim, pretty much says they will be pin compatible, so, why the keying change.
I hope there will be some brave souls to try bios editing and maybe some socket drilling ;-D
I said SOME boards, m4a79t with its inability to run 8gb (4x2gb) at 1600mhz in the first two mem slots without erroring out, not to mention for 3 months CnQ was stuck on and having to resort to all sorts of nonsense to make it work properly. now I'm not saying most of it wasn't fixed, but waiting the amount of time for asus to fix their bios was a PITA and don't forget the amount of dead MSI boards from thuban due to their buggy PWM. all in all there are always unforeseen issues one will run into however if it works that's fantastic but I'm just saying its more logical to not get your hopes up.
Stay tuned.
Hey Stranger....
Welcome back! :welcome:
Hope all is well with you and your family!
Not sure if you can tell us or not...
It looks like BD will work on the 890FX chipsets, but will 990FX offer anything new?
Lemme guess, thats probably where the "Stay Tuned" thing comes in.... :rofl:
hehe, here is it too :-D...Uff, about 2.5 months waiting, horrible :). But back to the mobo, still want see next 990 AM3+ boards. I seen only one :(
my guess is they will work on am3 but maybe not have all the functionality that am3+ would offer ie. powergating/turbo/etc..
and im officially tuned in :D
:up:
I completely agree. To say nothing of the fact that from my perspective, having an unused CPU sitting around in a box irks me a little, even if it's an older one. I'd rather have an old but functioning PC (complete with the MB that went with them) than a boxed CPU. At least with the older PC, there's always something I can do with it, whether that means turn it into a file-server, make it a bastion, or give it away to someone.
Whether I buy a BD or SB system for my next box, I want the latest generation chipset to go along with it.
Lets throw something else into the equation:
BD is HT3.1 - The Asus boards are HT3.0
Wonder if this will bottleneck it? But saying that if AM3+ boards are running on HT3.0 (890 chipset) I don't think it will be....
If Bulldozer works on AM3, wouldn't that mean it should work on AM2+?
Does Bulldozer have a DDR2 controller?
It might I don't know.
Howevers most ddr2 boards were using award bios's.
Those for sure won't get an update.
The boards that have ami's, the ones that eventually got 1090t support "might" get support for these.
We'll have to wait and see.
I suspect that the ddr3 and ddr2 controllers are one and the same, just setup slightly differently from the bios it's self.
I would not hold your breath though...
As for the DDR2/3 controller, yes its one thing that has two lets say "modes" however i doubt it will be possible to use BD on AM2+ mainboard,BD was designed from ground up with ddr3 only in mind.SO without some serious engineering its really doubtfulI would be up in arms tho :P
Would be good to know. Built a PC for a buddy when AM2+ was just getting "mature".
Since, he has: upgraded his vidcard, doubled his memory, upgraded his OS, added a couple of Vertex SSD's, and he's been wanting a CPU. Was about to pull trigger on a 975, but these rumors have me holding off.
That would end up being a helluva upgrade path if Bulldozer ended up working on AM2+. He could skip Phenom II and later still be able to upgrade motherboard to AM3+ and DDR3(4?).
EDIT: nevermind, not gonna happen...:flame:
The x4's are pretty good at 2.6ghz and above.
For pretty much anything you can throw at them pc wise.
Gaming, media, etc.
Even for encoding.
If you need serious power though the x6's and these x8's are where that's at.
We are only supporting AM3+.
DDR2 would never happen. Ever.
In days 2000 MHz+ DDR3 RAM would be ddr2 at bulldozer madness :D ...
