I don't think that would fit on my asus ch4.
Not unless I took a stick of mem out and went single chan.
Pretty sure that fan would get in the way because the heatsink is to short.
Ediit:
I'm wrong, the fan wouldn't get in the way.
It would still be close, with the 120mm+ width, there's not much room with the 80mm stock heatsink I got on there now...
Sits right against my mem fan.
I'm pretty sure this would not work if I were to try it.
It's still the usual up/dn arrangement with the fan.
Blowing the hot air towards the top of the case instead of the back, but to each his or her own I guess :),
I think it's odd how they are using the heatsink directly on the core like that.
Looks like a good idea in practice.
But those things are thin and hollow, they are supposed to fill them with alcohol or acetone but at some companies don't, thermaltake don't.
