I did manage to figure out a way to make Kombustor use both cards; rename the MSIKombustor.exe (whichever DX version I want to use) to Heaven.exe.
Thanks for the replies.
Anybody knows how to widen the scale ? I want to set 200mhz, but i can only try 405mhz, even that when i try rolls back to 500mhz.
So ATM i have to use Ati Tray tools to set clocks and afterburner to set voltage, which is weird to say the least ...
are you trying to set the idle clocks to something different?
which card are you using
Yes, i like manually setting every profile i need.
MSI HD6950 Twinfrozr II .
