wow.... that thing must be what the cookie monster is to cookies of dust!!!!
All up and running! Looks unreal! :cool::cool:
Got the DSLR camera out for these shots so they are better quality.
Sorry about the reflections, not much I can do about it without setting up a studio!
http://public.blu.livefilestore.com/...636.JPG?psid=1
http://public.blu.livefilestore.com/...627.JPG?psid=1
http://http://public.blu.livefilesto...628.JPG?psid=1
http://public.blu.livefilestore.com/...629.JPG?psid=1
http://public.blu.livefilestore.com/...631.JPG?psid=1
http://public.blu.livefilestore.com/...632.JPG?psid=1
http://public.blu.livefilestore.com/...638.JPG?psid=1
http://public.blu.livefilestore.com/...639.JPG?psid=1
http://public.blu.livefilestore.com/...642.JPG?psid=1
http://public.blu.livefilestore.com/...644.JPG?psid=1
http://public.blu.livefilestore.com/...646.JPG?psid=1
http://public.blu.livefilestore.com/...648.JPG?psid=1
http://public.blu.livefilestore.com/...651.JPG?psid=1
http://public.blu.livefilestore.com/...652.JPG?psid=1
http://public.blu.livefilestore.com/...655.JPG?psid=1
Can't see the pics :(
OMG photohop the macbook out :)
Nice setup I love when i see someone with too many computers I show my girlfriend and say see!! I'm not crazy :)
HOLY CRAP!!!
1st attempt at 4.6Ghz with new i7 950.....
Havent stress tested yet but this is the fastest Ive ever been!
http://w7st5a.blu.livefilestore.com/...dle.jpg?psid=1
Wow that's a lot of quick disconnects. Do you find yourself connecting and disconnecting quite frequently?
^and quickly? :D
Its easier for maintenance and safer for the components, since I can remove any component from the system without flushing the whole loop out.
Less chance of a spillage as they are high flow no spill quick disconnects.
Yes I have also changed my setup a lot in 6 months.
I have even changed the loop since initially building it because there wasnt enough pressure to push an even flow rate through the GPU's in a parallel setup, so they are now in series and it took 5mins to change without flushing the system.
Nice build, looks really good in the new case. And it also looks like your new CPU will do great. :up:
I'm just glad I'm not your pump though... Have you ever measured the flow of your system? All these blocks, 90C turns and tubing must keep that pump under some serious pressure?
New bench with memory at 2000mhz 9-9-9-27 and CPU @ 4.6Ghz
Vantage P41995 GPU 50440
http://public.blu.livefilestore.com/...ge2.jpg?psid=1
Here she is finished.. maybe a video another time.
http://public.blu.livefilestore.com/...661.JPG?psid=1
http://public.blu.livefilestore.com/...659.JPG?psid=1
http://public.blu.livefilestore.com/...662.JPG?psid=1
http://public.blu.livefilestore.com/...669.JPG?psid=1
http://public.blu.livefilestore.com/...671.JPG?psid=1
Woah! Core temp is reporting that your CPU reached 85C at some point? :shocked:
Now all u need a sweet wallpaper :D , i can hook uop with a awesome eyefinity 5760x1200 Res wallpaper, black background with eyefinity in RED GRAPH writing saying Eyefinity which covers all 3 screens, looks wicked man :)
thats come out very nice... :clap:
i cant wait for my EX- Ascension.
you need to tie all those cables behind your screens ...
Quick 3min video of IL2 in Eyefinity
http://www.youtube.com/watch?v=PbmEEi3R1lo
The companion cube. :)
Very nice build Phatboy69.
Any update on those temps?
No that's with fans at 900-1200rpm depending on water temp.
Going any faster just creates noise and doesnt really cool much better, maybe 2-3c better with fans on max and not worth the noise.
Ok, where do you measure the water temp, and are the rads hot?
Are you satisfied with those temps? :)
Why not take out the rads, and wire the fans on each of them together and only have 1 plug for the 3? Some heat shrink tubing to clean up the soldering and sleeve it and presto. Went from 3 to 1 single wire to control the fans on your radiator.
