Did you get your boinc from here?... http://boinc.berkeley.edu/download_all.php
Did you choose 48 AND 100% in device profiles?
Go to the Projects tab, select WCG, and then click Update.
Then, switch to the Messages tab and look for the line that shows Computer location: XXXXXX and make sure it shows the profile you're trying to use.
Thanks, I did the manual update, and now it shows the correct profile. Its still 32cores though. But I just read that local settings overrule webprofiles. I cleared the local settings multiple times, but I'm not sure that all is gone? Can I clean the local setting by hand?
Edit: You may want to stop boinc first.
Create and/or edit the cc_config.xml in your BOINC data folder and add or edit this:
<cc_config>
<options>
<ncpus>48</ncpus>
</options>
</cc_config>
then restart boinc.
references:
http://www.worldcommunitygrid.org/fo...d_thread,28926
http://www.worldcommunitygrid.org/fo...ffset,0#254638
My kernel is custom compiled for 8 cores (Ubuntu 10.04, Kernel 2.6.36.3) but the maximum if 512 (normally that is. It can be patched to use WAY more) I can't remember what the default was.
No, just ... no.
"Connected to localhost (boinc version number here)" means that the manager is connected to the local host, ie that machine. It has nothing to do with the settings.
To clear the local settings open the manager and click through Advanced > Preferences and in the top right hand corner click "clear".
Attachment 112167
Is this a work or personal workstation? If work, what is this monster used for? Please post ppd once you figured out how to get it to crunch all cores. Probably best to post this dilemma on WCG boinc help section.
Hi.
Nice rig :)
What OS is this machine running?
To force all cores in a windows environment go start>> run>> msconfig and go to the boot.ini tab then advanced options and tick the NUMPROC line and select the maximum threads / cores available and then reboot :up:
Like this:
http://i263.photobucket.com/albums/i...mm/numproc.jpg
Or edit the Boot.ini so it looks something like this:
:DCode:
[boot loader]
timeout=3
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer /numproc=12
A quick google run suggests that BOINC won't use additional cores until it's restarted, so make sure you reboot to be sure.
Well if you can just restart the BOINC client that would do as well. ;)
pirogue :cheer:
Get a sig like most of us have, I'd love to keep an eye on your stats :D
Sssssssmokin'!!!
Awesome piece of hardware right there, me wants :D
Now, post your first day's results...:D
looks like a healthy 100+k per rig, congratz on these babies
are these magny cours servers?
Can you post a large screenie with boinc WCG running (all processes visible) + a task manager with all cores 100% ?
It's for my bathroom door you see :D
