Hardware RAID controllers use different, proprietary disk layouts, so it is not usually possible to span controllers from different manufacturers. They do not require processor resources, the BIOS can boot from them, and tighter integration with the device driver may offer better error handling.
^^^^^must have dedicated processor
These controllers are described by their manufacturers as RAID controllers, and it is rarely made clear to purchasers that the burden of RAID processing is borne by the host computer's central processing unit, not the RAID controller itself, thus introducing the aforementioned CPU overhead from which hardware controllers don't suffer. Firmware controllers often can only use certain types of hard drives in their RAID arrays (e.g. SATA for Intel Matrix RAID), as there is neither SCSI nor PATA support in modern Intel ICH southbridges; however, motherboard makers implement RAID controllers outside of the southbridge on some motherboards. Before their introduction, a "RAID controller" implied that the controller did the processing, and the new type has become known by some as "fake RAID" even though the RAID itself is implemented correctly
