Yeah, you have some good points there. Maybe this new 25nm NAND had some surprise for controllers?.
OCZ-problems, as you describe it, seams to be related to the combination of the controller + 25nm NAND. And, Intel seams to be using the delay-time to fix the controller to work optimized with this new 25nm NAND, too.
I don't think there is problem with the quality, supply or yield of 25nm NAND by itself, because Intel is confident enough to sell them to OEM already. To me, the problem seams to be related to OCZ and Intel's controllers in combination with 25nm NAND.
