CPU score is weird.
Could it by Physics plus throttling? :shrug:
3 PSUs and so many pots... :eek:
Gratzy ! ! !
Crazy clocks and scores as always Duck-san:shocked:
Awesome work :)
firstly congrats to you duck-san, nice result, it is great to see you and fellow team japan members benching 3D, we were always hoping you would start benching 3d!
secondly ME4ME, gt are down because in 4-way GT are basically a CPU test and iirc Vince has almost 150-200 MHz on Duck on the CPU, this would equate to a high boost in GT1 and big in GT2 also.. you simply can't make use of that massive GPU power without the CPU clocks to match... i bet 1050-1075 MHz on the GPU would yield a similar result..
kingpin has a back up?
Holly cow, you're getting crazy, Duck San, so is Galaxy !:D
Nice 580 & excellent work:up:
Send me a sample of this magnifier, would you !
I need that for a 4x 580 WR :p:;)
http://i967.photobucket.com/albums/a...5/850ec1ba.jpg
Dear James, Mad, and Dinos
Thank you! :up::up:
Brian, Oliver, George, Oj101, miahallen, over@locker886, Maj0r, GHZ ,scooter,Boulard,
DomagojX,Hondacity,slamms,ExpatGriz,1Day,Johnny87・ ・・・
Thank you all for your comment. :up:
Hi ME4ME-san
CPU score looks strange as you pointed it out. :yepp:
But I of course turned off PhysX and didn't do anything "special."
Sometimes my SR-2 system boosts up when I run Vantage repeatedly under the
same clock(both CPU and VGA).
In the past I saw CPU score exceeded 100K on my system with PhysX turned
off.
This time, when GPU clock reached somewhere around 1150MHz, CPU score
started to boost up, yet GPU score didn't go up.
I still don't know why this happened, it is a mystery.
I talked to the EVGA people about this before, but no clear answer.
My SR-2 system can run Vantage with CPU at Over5.4GHz, VGA clock 1200MHz x 4.
But this time, somehow score didn't go as high as I thought it would.
This score is just a beginning.
I am planning to give it another shot in the near future. :)
>No hard feelings
I don't mind it at all :up:
Those gpu clocks... are CRAZY!
Same as the resulsts.
Big Gz really. I didnt knew those galaxy were able to reach such clicks.
:clap::clap::clap: Congrats Duck-San really nice SR2 action, not easy bench with that platform :up:
5690s = 100K CPU anyone?
Congratz Duck-san:):up: Beast of a set-up, man.
GPU settings (clocks/voltage) can positively effect the CPU portion of the score, even with physx-off. Also, conversely sometimes you can surprisingly get through GT1 & 2 with real high GPU clock, to only have CPU tests die on you...drop the GPU clocks, then CPU tests finish. There seems to be an efficiency setting that the GPU/CPU work well with together...the trick of course is finding that setting, lol. That's my experience anyway. And Evga don't know jack about the intricacies of any benchmark application. They sell product...ask K|np|n, he's the one with the answers.
Great achieivement, 4-way is so hard to bench especially alone :) Overclocking doesn't get much more badass than this.
Wow, truly amazing. I <3 when I see a thread started by duck. Congrats!!!
Amazing
Thanks all.
I was very confident of this record from the beginning and posted it on the
web..
CPU clock seemed a bit low, however GPU clock is at 1170MHz and I thought it
was a possible score.
I felt a bit strange about the CPU-Test1 figure, but I can make the same
score again and again anytime.
I have posted the score under the same status before on the web, and nobody
ever suspected or pointed it out back then.
However, I discussed with the people engaged in SR-2 designing whom I trust,
and I found I was wrong about it.
It turned out to be a possible bug, and it was a impossible score under the
system environment.
Therefore this score should not be recognized as the record and I believe
the record must be recognized by a third party. :yepp:
But I will not give up and will try again soon. :up:
By the way, this is the second best score I set during the try.
http://tokyo.cool.ne.jp/yasukazusimo/galaxy580/72k.gif
Wow duck... I like that score better! It makes sense lol!
Awesome benching. Bugged runs are no fun :(
Actually physx affects the second CPU test, but not the first.
So if physx was enabled, his second CPU test would be off the chard.
Cpu test 1 seems right tho. Most likely his uncore is a bit higher, which greatly affects the CPU-1 score.
Also, were the GPUs hard-volt modded, or just an unlocked bios?
