What did you change to get the 8-8-8 stable, Lsdmeasap?
I am not sure how stable that is, but for sure better than the previous attempts where I couldn't even reboot upon saving.
I switched slots, and updated to the BIOS that just came out (F7d). I don't think the BIOS had anything to do with it, more likely the slot move I'm thinking, but I could be wrong.
I'll test later tonight back in slots 1+3, and with the older BIOS back on 2+4 and see which move it was that made it bootable.
777-24 still a no go though no matter what, and since others can do it easy with similar memory I really think that whether these speeds are going to work for a user or not is going to depend on the CPU itself.
I just passed 32M at 5GHz DDR3-2133 8-8-8-24 88 1T
That is with the UD7 bios F7d, my DIMMS are in slots 2 & 4
2133 7-7-7 has never been good for me on my ES or this retail chip.....but 7-7-7 was fine at 1866 as you stated Ed ;)
These DIMMs also run fine at 1866 6-6-6-18 60 1T on x58 with 1.7V....but they wouldn't even boot with my ES D1....still have not tried on my retail D2
i will try move from 1+3 slot to 2+4 slot
http://i161.photobucket.com/albums/t...len/hyper6.jpg
http://i161.photobucket.com/albums/t...len/hyper5.jpg
http://i161.photobucket.com/albums/t...len/hyper4.jpg
http://i161.photobucket.com/albums/t...len/hyper3.jpg
http://i161.photobucket.com/albums/t...len/hyper2.jpg
http://i161.photobucket.com/albums/t...len/hyper1.jpg
Thanks a lot miahallen!
Woo,System Agent 1.1450V,will try your setting.
Super PI 1m passed,will try 32M.
http://img683.imageshack.us/img683/7...0120114052.png
Edit:
With this setting I have load Core1 50% and Core3 30% all the time ?!
Edit 1:
SetTurbo Boost to Disable and no load on cores.
Super PI 32m freeze on start.
in my thread i was running
1067MHz 7-7-7-21-1T 32M easy
but i needed 1.24QPI/VTT and 1.78vdimm, that was the key for me, system agent didnt do anything
http://www.xtremesystems.org/forums/...d.php?t=265130
i recommend using slots 2 and 4, it seems to be a bit better
Dino,how far you can go with 1.66vdimm?
my hypers live a happy life between 1.7 and 1.8vdimm :rofl:
So you use more system agent than what some have recommended as well eh? Clunk told me he noticed improvments at higher clocks with tight timings using 1.3-1.4 VCCSA, UD7 stops ate 1.305 :(
So if this is a needed setting change for some clocks hopefully Gigabyte will increase the allowed amount on this.
It's too bad all CPU's wont take high QPI/Vtt, the one I have stops booting at 1.2, sometimes I can get 1.22 to post but not often.
I always use extreme on the performance enhance, do you think that holds me back? I know on X58 and P55 it was the most stable and provided the best bandwidth for sure!
Hey, would you mind passing this info along to the BIOS guys and see if they can address this in our BIOSes, or add the optional setting, I think it applies to us as well.
http://www.xtremesystems.org/forums/...d.php?t=265454
I'm about to try out SS on one of these setups, I know many say it doesn't clock well like that, but since release I have seen quite a few using phase with positive results.
Seen anyone on Dice or Ln2 with these yet?
just put it in UD7 also and it does 1067 with same settings easy
hey Ed yeah mate all IMCs will be a bit different i guess, i am just reporting on my experience. i just bought a retail CPU and have to go pick it up tomorrow so will see how that goes too
http://img130.imageshack.us/img130/4...ud7superpi.png
@Dinos22: have you tried the Hypers on slots 1 and 3? I've tried PSC chips on both 1/3 and 2/4 and have good results. Haven't tried the Hypers on 1/3 yet.
Does the cpu batch have anything to do with this? :confused:
i did in UD5 and 2 and 4 were better
just put it in UD7 and they didnt even boot from 1 and 3 eek
1+3 is what initially gave me issues too!
I'll be going back to verify though, but it does seem like 2+4 is better.
CPU pulling down now :D
107.8 first boot and first settings plugged in, I think 110+ is coming soon :D
http://img193.imageshack.us/img193/3061/1078.png
What's the current record Bclk?
Thanks. I'll try this with the Hyper when I get back later today (UD7).Quote:
My Super Talent 2000 CL7 will will run 2133+ 8-8-8-20 T1 thru all benches except for spi32m.
OCM :up:
yes
u didnt see the thread i linked
http://img692.imageshack.us/img692/3...77721witha.png
