Let us know if the performance is correct for it now! Grats and hope so... I may switch to 2x 6950 to unlock to 6970, instead of my GTX 580 if this works right. Tempting, but not sure it's worth the hassle/risk of not unlocking two cards properly...
flashed.
got to try.
worked.
2 6950 Powercolor
However, seeing artifacts in 3D and benches wont run.
gpu-z shows 1600unified shaders.
so, seems this is a luck of the draw to get a working ex for unlock.
wait a moment it on benching now, i try for clock per clock of gpu with before
and after flashed ;)
Okay quick results from my Sapphire hd6950 flashed to Asus hd6970, for bios flash method not any specials you can see from #9 on
this thread on first page and must thank you to Pyr0 for his sharing of method
first let to see bios flash screen for confirm is i used true Sap6950 flash to Asus6970
http://img831.imageshack.us/img831/2500/img8424r.jpg
Results from original bios of sap hd6950@800/1250MHz (stock Freq.)
http://img407.imageshack.us/img407/5784/sap9650.png
Result after flash to Asus hd6970 and benching at stock frequency of asus bios@890/1375MHz
http://img839.imageshack.us/img839/9427/sapto6970.png
Score from 3Dmark11 increasing about 500Mark and this scale same as from older my results on review between 6970 and 6950
but wait to see more for MHz per MHz :)
wow it's nice to see that zolkorn :)
Hey guys, started new thread to make it clear to outhers what seems to be working
http://www.xtremesystems.org/forums/...d.php?t=264159
@ZoLKoRn, thank you very much! Performance difference is caused by increased clock speeds. Could you please test at the same clock speeds with berfore/after BISOes?
It coming for the same clock speeds with berfore/after BISOes, and for more approve of score i tried to running three time for checking on new Biosed and
results looking increasing about 100mark all time. ;)
Running #1
http://img262.imageshack.us/img262/3...800mhzrun1.png
Running #2
http://img408.imageshack.us/img408/8...800mhzrun2.png
Running #3
http://img146.imageshack.us/img146/1...800mhzrun3.png
Well for stock bios it can did score only 45xxMark, So how everyone thinking ?
one more result for try to overclocking :D
http://img263.imageshack.us/img263/8746/sapto697oc.png
Thank you. ;)
@ZoLKoRn, thank you very much! Actually we need results of following situations to compare performance within two BIOSes:
1- Default Sapphire HD 6950 speeds with Sapphire HD 6950 BIOS
2- Default Sapphire HD 6950 speeds with ASUS HD 6970 BIOS
@ ZoLKoRn
what were your default 6970 card results?
roughly the same as the 6950 flashed to 6970 ?
i'd like to see if the shaders really are unlocked. can it be read from registers or something? i think GPU-Z is just reading built in data depending on the card IDs
I'm back to running 6970 now for checking on stock clock and overclock same as here for 930/1450MHz let to see what happen with it, wait a moment ;)
Edit : i think shaders it working, now i tried running asus card on stock clock it score showed 5004point now (screenshot to come)
Edit2 : Well done ! checking from here with i back to running my asus card at both clock is i tried on sapphire@asus bios from #29
real asus card with stock clock - 5004point (sapphire@asus bios - 4998point from #29)
http://img46.imageshack.us/img46/7161/asus6970.png
real asus card with oc@930/1430MHz - 5158point (sapphire@asus bios - 5154point from #33)
http://img839.imageshack.us/img839/1637/asus6970oc.png
so finally i think shaders it really working for unlocked :rocker: nice one again for AMD ! :D
I flashed my sapphire 6950 with the asus bios before I really ran any benches but at
900/1350 3dmark 11 went from p5363 to p5470
so it looks like it unlocked and though I was hoping the shaders made a bigger difference.
I would of thought the extra shaders would of had a bigger impact really.
Sounds great.
But smartdoctor (voltage increase?) isn't working?
What happens if you try the voltage increase? Does the card get any higher clocks on GPU? (even if gpu-z isn't showing it?)
ดังใหญ่เลยนะท่าน..อิ..อิ..Good job
did anyone try the sapphire tool called TRIXX to increase voltage on 69xx cards?
Good job !!
Ok, another question for OP and anyone else:
If you flash a 6970 (not a 6950) to an ASUS 6970 bios, does the overclock increase or remain the same as before?
(without using Smartdoctor, so, stock volts only).
Zolkorn?
Wow
Checking here on ASUS Smartdoc and done ! ;)
http://img697.imageshack.us/img697/5443/smartdoc.png
Thanks image from Pyr0
