XT u dont need two 90 fittings, 1x 45 and 1x 90 .. HF is fine either way.. havent had any troubles with my HF..
Are you sure about XT? The Holes (Inlet - Outlet) are very near!
HF, u say that will be ok with 90o compression fittings such as these huh?
http://www.aquatuning.de/product_inf...----Black.html
The EK-Supreme HF will be a few degrees better but I would go for the swiftech, its a good performer and its so easy to install :)
If i have to turn the Inlet at 90 degrees, i must open the block to rotate it.Quote:
I think that this is difficult.
+1
Very Nice!:up:
