The extender dont work for me :(
Wow! That sucks then. Is it the fittings your using? I'm using bitspower fittings?
Im using Bits 1/2 all the way. But i ordered Feser compression for my GTX580 to make it "classier" but it wont fit.
Boulard, have you tried any BP fittings on your blocks? It's not the end of the world if I need to use a normal fitting, it would just be a shame not to use these compresions ( won't use extenders )
Im 100% fine to use straight BP fittings ... its just a lil less "classi" ! i could use larger spacer from koolance or other companie.
http://www.infodupat.com/MiscPics/decembre_01.JPG
@boulard that a DD torturerack?
+1 Waterlogged ;)
http://www.tecnofront.com/
My case : http://www.tecnofront.com/hwd_01_it.htm
Buyed from Perfomances PCs.
thanks
all card will fun with WC
@Waterlogged: Their benchtable seems fine to me. Although I'm a fan od Coolermaster's Lab Test Bench. The only downside - it doesn't have a PCI bracket holder therefor the card with heavy FC wateblocks or LN2 pots tend to wobble a bit :P. I have to get a few pieces of the holder machined and bent to fit :D
So if I have Bitspower 1/2 3/4" I will need to use some kind of extender?
We're at EK are designing a new waterblock for GeForce 580 GTX with built-in brass standoffs.
Best Regards,
Niko :up:
tiborr: what are flow differences between the blocks? I'm guessing that microfins are much more resistive then old basic waves?
:up:
tiborr: Does new revision have different base only, or block top has been modified too? If former, maybe you could think about some upgrade program with only replacement base being sold separately?
When will this GTX580+ be released? Can't find it in Australia yet.
Yeah not real happy my block is obsolete. Those temp differences are huge.
Indeed... just bought mine as well... :(
Now I have to do another NV roundup... damnit.
:D
