11.000 * 4000 = your efficiency 44,000
7.551 * 5000 = his efficiency 37755
That means at your 4GHz he'd get 9.439s, and at his 5GHz you'd get 8.800s - a 17% difference clock for clock!
i would buy 2500K / 2600K !!!!!
7.55s 1m is very fast for 5ghz. My 920 at 4.9+ghz scores 8.233. He is on air, compared to other cpu's running around the same times he is very fast, most are well above 6000mhz to get the same score.
Weird to see two 8-pin EPS12V connectors on such a simplistic board. :lol:
5.0ghz @ 1.45 vCC? :D sounds like the old C2D (E8600) ... the LGA 1155 seems to be really interesting ...
That screenshot you took is of 7.05- 7.06 second runs not 7.55
Just so you know...
Looks to be good efficiency though, better than X58, although not insanely much.
TBH this looks more like a die shrink, with limitations. Will see if manufacturers get around this limitation somehow as they did with the ones on the X58 platform.
Definitely looking forward to more results.
Sry my bad.
Windwithme, Nice Bench! looking forward to see more :)
Man I want one of those and a UD7...
I already see 5.5ghz watercooled, pair up with a couple of graphics :D
Damn you are a visionary :D
风大的帖子总是很厉害!Will dual core sandy be even better for oc? It's sad if they'd not offer unlocked multipliers for any dual core sandy.
World records incoming!!.
please give us some 3DMark runs to compare :)
5GHz benchable @ <1.5 with ΗΤ @ air is promising - can't wait for the dual cores :shocked:
wow look at those insane write/copy/latencys!! impressive as hell! Cant wait for there high end in 2011.. their 1155 already owning up the current competition..
wind: What is the max stable clock in PRIME95 or LINX? Thx
This is amazing, waiting for more
BEst regards
It's Chinese for Wind ;)
Or are you addressing him?
