Still weren't running the same build (version) of the game, want a cookie?
This is my max clock I was able to reach. I tried 970mhz, but it crashed.
http://a.imageshack.us/img573/4557/gtx580960mhz.th.png
anyone see a correlation to pcb color and vid ;)
Is the old crysis demo anyhting even close to the retail game any more in terms of rendering capability?
Yep i only got 33.665 fps on his build, thanks for letting me know about the build version i didn't realise i patched mine but next time don't be a :banana::banana::banana::banana::banana: about it i can accept i made a mistake when taking the bench but you rather just be a big kid and still point fingers good work man :P.
@ ts = any WARHEAD score ?
http://img534.imageshack.us/img534/8642/cwcfdef.jpg
I think my 580 is slowly dying :(
It seems I have to keep bumping up the volts slowly on stock clocks just to keep it from freezing with some minor artifacting. Stock vid is 1.013v, then I bumped it to 1.025v which eventually wasn't enough, and now I'm at 1.038v to keep it running. I guess it might be time to RMA.
nice :toast: not bad :up:
reinstall the drivers as that has been the issue from the getgo and dont use any oc app and see how it does
if that doesnt do anything try another psu if you got another
or what trn said above ^
my 580 still going strong
@ ts = any WARHEAD score ? :) not crysis score....
i wonder did single 580 oc can kick def 6870 CF on WARHEAD ?
ill do crysis warhead/redo everything monday on a new system :)
till then heres stalker cop @ ultra default settings to give you an idea where its at
http://img837.imageshack.us/img837/1015/71649488.png
let me see if i got warhead if i have it will post result tonight
If you looked at one of my previous post I actually fixed the driver issue. I installed it in a slightly different way. I used device manager to uninstall, and ran a driver cleaner in safe mode. Then I reboot and install the drivers. Well on top of that I used the clean install function that nvidia provides when you install their drivers. Long story short my frames improved after a proper install and things ran smooth.
Now when you say don't use any overclocking app what do you mean? Not have any app installed at all when testing?
I may try it if worse comes to worse, but as of now I'm just about convinced the card is no good. Hopefully I can figure out the problem if possible.
ya game at default clocks without using any oc app
msi 580 vid 1.00 :D
950 stock voltage for 03, 2am so tryed trolls at 1000 and passed with 1.13v
Well to eliminate the problem I proceeded to just uninstalling all gpu related overclocking programs. And to my surprise it helped a little. It didn't crash as fast at stock voltage, but it still crashed which still bums me out.
I think I'm gonna just reinstall the drivers just one last time. If that doesn't work, then I'm getting a replacement.
