My guess is that the wires were wrong on the power supply. If you look closely at the SATA power, pins 7 to 9 are cooked. If you look real closely you can see that the coating on the PCB was burned off and the copper is showing. Pins 7, 8, and 9 are all +5VDC. Being that it looks like current ran from pin 7 to 9(or vice versa) I'd say that pin 7 and/or 9 were possibly wired wrong. Perhaps power went in through the SATA power and out through the SATA data cable via ground?
In any case, I'd put money in it being a power supply issue since these drives were used before. As much as I'd love to see the wires on the SATA connectors, I'm not sure we'd be able to identify which cable was connected to which pins inside the connector. For molex connectors they'd be very easy to identify.
