Oh ok, so your method was better than mine to remove this nasty stuff :ROTF: I will remember it, if i have to do such work someday in the future :yepp:
Very uniform, can't wait to see the GPUs in there! (1000th post)
the GPU ... AND the sound card! they're both pretty... but don't be so impatient ;)
time will come!
here's a bit of news...
before:
http://dr.pfeffer.free.fr/pc/dec14.jpg
after:
http://dr.pfeffer.free.fr/pc/dec12.jpg
http://dr.pfeffer.free.fr/pc/dec13.jpg
closed:
http://dr.pfeffer.free.fr/pc/dec16.jpg
open:
http://dr.pfeffer.free.fr/pc/dec15.jpg
http://dr.pfeffer.free.fr/pc/dec19.jpg
http://dr.pfeffer.free.fr/pc/dec20.jpg
http://dr.pfeffer.free.fr/pc/dec21.jpg
from the inside:
http://dr.pfeffer.free.fr/pc/dec18.jpg
http://dr.pfeffer.free.fr/pc/dec17.jpg
I'm in love with that case :yawn:
Keep going! :up:
I also got this case :cool:
Will be folowing it , nice work until now;)
looking good mate!!
looking good matey!!
little update for the new year! ;)
http://dr.pfeffer.free.fr/pc/jan02.jpg
http://dr.pfeffer.free.fr/pc/jan01.jpg
http://dr.pfeffer.free.fr/pc/jan03.jpg
That reservoir placement it's so tight wow! :D
Nice mate, U should of added atleast 1 cable sleeved black on each cable.. Would of been rad man!
yep, as you say... pretty tight, but it works just the way i thought ;)
i thought of this, but finally i decided to keep it all white, so the cables coming out of the PSU look all the same (would be kinda messy otherwise!)
Going to use black or white tubes?
white tubes and black coolant... you'll see that soon!
I believe white tubes will be perfekt. Matches the sleeving.
Looking forward to seeing plumbing.
me too ;)
Did you paint that front metal plate? I think you did, but I can't tell from that one picture almost still looks metal to me 0.o.
It's been white painted... I know the picture quality sucks!
Is that a sheet of plexi behind your mb?
Did you drill holes for the standoffs, or did you mount the MB to the plexi?
"behind" the mobo, on the bottom of the case, and maybe around the PSU/back fan too...
no the plexi goes around the mobo, the holes i drilled are for cables and tubing!
i have a week off next week... should be finishing this baby !! ;)
Any plans to do lighting with the acrylic?
there is... but no more info yet... too soon!
you'll see that too! ;)
Very interested now.
