@Tim, that is exactly what I was looking for, thx!
@Toolius, yes, that will work... how much restriction you're going to add, not exactly sure, but pump redundancy is what you're after anyway.
Thank you Sir Skinnee !!! :up::up:
You just made my life much easier :yepp:
For now am just going to cool the Cpu and MB with 2x GTX360 rads. Will add 2x gpu's to the mix later on but am waiting for the Ati 6xxx Series cards before i decide on what gpu's to buy. Do you foresee any issues ?
Thank you again Sir Skinnee. Much Appreciated :yepp::up:
Yep that does make sense millertime359. Didnt think about it like that. :)
Am definitely getting one to try out if its possible to use 2x D5 in serial on this for a single loop. Figure since im getting a ton of w/c stuff for 3 of my systems shipped all the way to India might as well get this too.
Thanks a ton and kind regards :)
Its hard to tell but is there a grain to the front Aluminum plate? Looks like it was bead blasted and anodized?
This product is now available for purchase (link).
You're correct, it's not technically isolated dual loops with a common reservoir. We've changed the product description.
There's no grain, it's smooth aluminum. You can just barely make out some machine marks if you're close and hold it to the light just right.
Tim
WOW!! Looks great Tim, nice bit of engineering!!! :up:
Any chance of building a version for dual PMP-400's?
It looks great Tim. Going to be interesting to see test results. :)
I knew there was a reason I included a triple optical in my custom case. This just about nails it.
I hate that i keep wanting more and more parts Lol.
What i like is that looks deep enough to work on tubeing attachment while its installed. Which what i hated about shorter bay res's. Large hands didn't really fit in there.
Sent from my X10a using Tapatalk
Any chance Tim if we can have a snapshot with some LED's on. I noticed one pic with the green fluid has some wired up but not on.
Just snagged one..shipping to Europe was a bit excessive but have been looking for a solution like this for a long time....couldn't help myself!!
Price isn't bad considering your getting two tops and a res. Would like to see an alternate version for 355s
This is one sexy looking res ! Nice work !!!! :up:
Just got one too :)
Woot cant wait for this baby to land !! :)
I am in love. I am about to buy it but my total with 2 pumps is :) 280$ and thats kind a high for me at the moment ;) but i see it coming ...
Looks perfect for my needs, but i'll be waiting for some performance numbers.
I'd prefer the DD 3 bay, but i dont really see it being made any time soon sadly
Tried a similar thing with my XSPC dual DDC bayres (old type)
http://i232.photobucket.com/albums/e...e/P1080557.jpg
Didn't help temps much, just lots and LOTS of turbulence in the res :)
Thank you soo much biffa :)
Feel much better knowing that it should work. Have one on the way and i had this doubt stuck in my head !. Much appreciated :)
Cheers and kind regards !
Stunning!!
Looks real good. Good stuff having that kind of choice now, we have been waiting a long time for such products...
noob question, I still have the pump from the T3 without the "housing". Does anyone know if this work the same way? because I'm not sure if I need any additional parts that would prevent it from mounting on the res.
Thanks. Other pump options are being considered.
That's one reason we designed it with the option to run a single pump. Then customers can save up to buy the other. :)
The web picture with green fluid is lit with 4 white LED's on the top and bottom. It's not easy to tell with all the other lights going.
http://www.koolance.com/water-coolin...p-450x2_p5.jpg
Tim
First, love it. Looks awesome and it's an easy way of having two loops. The only thing I can find fault with is that since it is sharing the same res it would have been nice if the two pumps could work together like the EK MCP655 dual top and res. This way if you did have a restrictive loop or you wanted to use it for redundancy then you could. As it looks now, if one pump goes down then that loop just sits idle, so it's not redundant, unless of course I am missing something in the drawings. Overall, I think it's a sweet product and it definetely would save space in some tight cases. Price is what I would expect for a full delrin part.
Does this help your consideration?
http://deephousepage.com/smilies/gonnagetit.gifhttp://deephousepage.com/smilies/gonnagetit.gifhttp://deephousepage.com/smilies/gonnagetit.gif :D:ROTF:
For those wanting to "redundant" their loop, you might consider adding a couple of these to it. ;)
http://www.koolance.com/water-coolin...product_id=667
Yes, you could run from pump 1 out to pump 2 in and now it's redundant, but that requires more fittings, but it's not a bad solution.
Edit: The only issue I see with doing this is that air may get sucked back into the loop due to the port configuration with the res in being on the bottom and top with the outlets in the middle. Air from the bottom could get sucked in by one of the middle outlets regardless of the separaters.
Super smexy - if I were a guy I'd of jizzed my pants :P
~Bex
