Maybe OP can edit the first post and keep another tally. :)
I have both xspc and EK top, first I ordered xspc dual ddc top... used some time to finish pump mod about to get finished i noticed a few microfractures in acryl , had read around on XS that xspc had a few issues decided to go EK dual top V2.
(Loop are reservoir (400 mm) -> EK dual ddc top with multioption reservoir (60 mm) -> radiator -> qdc -> cpu -> sb/nb chipset -> mosfets -> mips ramcooler -> qdc -> AC flowmeter -> radiator -> qdc -> 2 x 5970 in paralell -> qdc -> mips ramcooler (cools 2 x mcubed miniNG) -> chipset cooler (cools mcubed BigNG) -> back to reservoir
waterflow 291 liter/hour)
I run 8 DDC's with XSPC tops, most are over year old, not a failure yet... crosses fingers. had one D5 go bad, that is it for pump failures, that were normal deaths, not due to me over/undervolting, or modding.. :p:
My EK dual ddc V2 pump 1 4700-4800 rpm pump 2 5000-5100 rpm
temps on pump internal hits 46-47 Celsius
Anyone else having trouble adding up the percentages to 100%..:D
I spy vBulletin bug..
Quoting myself ^ ... I just checked the current on this pump and it's only pulling 1.28A at 12v.
Since it's still within spec, I'm going to leave it in the loop until it gets worse.
Loop = pump to PA120.3 to PA120.3 to swiftech GTZ to ported AquagraFX fc block to iandh res using 30 inches total, of 7/16 tubing.
i tried, I can't edit the poll options.
I would be better to write how many pumps you have.
Regarding the stock pump: it does not matter, since you can call warranty on a stock not moded pump fail.
Regarding the XSPC Res/Top, they look similar but since it is the most popular res/top solution I want to know if they have the failure rate of the top only model.
Remember you can vote in more than one top.
Zern P12 - quietest top that i know, followed by Koolance PMP400 (old metal version) or the Phobya Metal Top
EK and Watercool Tops are much louder !
http://www.youtube.com/watch?v=Z541Ri87TMw
http://www.youtube.com/watch?v=HX3wynmQxKk
http://www.youtube.com/watch?v=v4os7Kv2lNg
http://www.youtube.com/watch?v=dPLsZqarZUo
Yes, i made a review last year
http://www.xtremesystems.org/forums/...d.php?t=258969
The new PMP-400 is a bit louder than the old PMP400 Metal top :( So, the zern top is the quietest atm
No :( Here is a contact formular, if you want to ask them:
https://www.zern.at/zern_shop/de/cms/7/kontakt.html
Both - I got 8 PC´s
