Professional & Ultimate will only support 2 CPU sockets. You'd be limited to two Barcys with Pro/Ult...
Server 08/08r2 not working? :(
Has anyone tried Server 03r2?
I think Sparky tried server 08 without success. I'd like to see if 03 would work
Correct. Can't boot direct from the DVD because of the lack of full ACPI (starts to boot then BSOD with an ACPI error). The EFI shell hangs at detecting the SATA DVD ROM drive. Copying the contents of the DVD to another hard drive and trying to install that way just made the system hang... :shrug:
An interesting tidbit of info that I did find, somebody on some other forum somewhere was modifying bioses for some other Arima boards to give full ACPI functionality to allow windows to load. He hadn't done one for this board, nor do I know how you'd even go about flashing this board's bios, but maybe if someone can figure out how to do that we could then use any windows server version.
Sshhhh Don't tell everyone .....the ones I sent out are 1.6A 12v..>..19.2watts
Aw.. I was kinda hoping that Vapor's thread was wrong :)
An I7 860 setup still holds that crown I believe, as they consume less from the wall?
Just a quick setup I picked out;
i7 860 £211.49
Asus P7P55D-E LX £99.99
Corsair Dominator 4GB £79.89
OCZ ModXStream Pro 600w £64.61
Total £455.98
My quad's cost me
CPU's 8356 x 4 = £151.00
Board = £105.00
Ram 16 x 512mb = £40.00
PSU = £60.00
Heatsinks = ~£50.00
Adapters = ~£8
Total £414.00
You could prob get a cheaper i7 setup than what I picked. It would fit in a standard case. And it would just work out of the box.
But where's the fun in that :D
2008r2 should work as it's based on windows 7 and they support EFI.
http://www.microsoft.com/windowsserv...are-specs.aspx
And every version of 2008r2 supports 4 cpu sockets ecxept foundation version.
I'll be trying soon. Chips today, power supply+adapters tomorrow. Think I'm short on brackets though, doh.
no biggie you can add the other brackets and cpus later. i wanna see some windows magic out of you lol!
ok new thought: is there any way to adjust the cpu fan speed? they run slower as the bios loads up then ramp up to full speed right before it loads into ubuntu.
Fan controller! :P
Why are all the decently priced brackets in Hong Kong?
what do you want the fans to do? full speed from the off? connect direct to psu!
oddly enough on my sm board they spin up full then drop back to temp related speed if allowed in bios.
Very nice work Kryja :toast: :clap:
FYI, if you need a cheap graphic card for these there are several x300 PCIe cards on ebay right now for $10 shipped that work great.
Updated the first post.
I've made a few small amendments here and there and added a couple of Questions & pictures . Again once mine is up and running I'll test the minimum amount of ram these things need to post.
Got a small problem :confused:
I have setup my board with 1 CPU and 4 1GB sticks in CPU0_dimm0-4.
The board boots up woo! But it won't load into the BIOS, it just hangs on "entering setup"
If I don't enter setup the board posts and I can get into the EFI shell, etc.
Also another weird thing is the BIOS loader graphic says OBEY and has a picture of a bloke :rofl::shrug:
http://i216.photobucket.com/albums/c...t/XS/photo.jpg
I have special plans for my ARIMA with 4 Quad-Core AMD Opteron 8358 2.4Ghz CPU's.
Im going to try how this rig works as how gaming goes gonna put gtx480 or my Ares card to this and bench it :)
After that, i go and put it as dedicated wcg rig.
Edit: And yeah, i bought one PCIE 2.0 x16 raiser so i dont need care about those caps and buttons.
