Quote: Originally Posted by Hondacity hicookie the resistor is already 5k-ohms ... its not 16.7k-ohms is this a new revision board? my board came with F2 bios. i already have the isl6344 datasheet ...weird that the resistor is 16.7k-ohms are you sure?
i did OCP mod and with the VR set to 100k i read 14,6Kohm so i think it works... i had problems without mod, not with OCP seems ok
Quote: Originally Posted by hicookie are you sure? yeah measured it again this morning...the original resistor(16.7kohms) is 5kohms Quote: Originally Posted by KanGaXx i did OCP mod and with the VR set to 100k i read 14,6Kohm so i think it works... i had problems without mod, not with OCP seems ok where did you measure the 14.6kohms? thanks
