would love to know if the the E5620 works in any of the low end Asus mobos.. :up:
Does anybody know, if it's possible to overclock this CPU with 20x multiplier (though it has 2,66GHz Turbo clock it shouldn't be a problem?)
I found information it works on GA-X58A-UD3R which is not so expensive, anybody confirms?
I bought an E5620 cheap on South African forum , bought Gigabyte X58A-UDR3 ver.2.0 and Corsair XMS3 1600 CL8 6gb kit . Tried cpu with default bios ( never was able to see what version BIOS was - no boot ) . I couldn't update bios as I had no compatible cpu for the board , so I sent the board back to my supplier and asked them to update to latest official BIOS ( FE at this time ) . Tried again - still nothing . Then I updated to latest beta BIOS ( FF1 at this time ) from Stasio @ the Techpowerup forums ( this time I had i7 950 to update ) , then , with 950 installed , changed multi to E5620 multi , and set uncore , DRAM and QPI ratios to lowest possible . Low and behold - the damn thing started ! ( All this is today , after 2 weeks of missioning and tears ) . Now I have CPU set to 211 x 19 ( you have to have turbo enabled to access 19x multi ) @ 1.35v under Corsair H70 . Must still check for stability and mount cooler properly with TIM properly applied . I will post some screenshots as soon as I've confirmed highest stable OC . I hope this helps - I struggled for 2 weeks trying to get this going and am now fully amped and stoked and happy ...... ad infinitum . :)
I can confirm that my E5640 works with my Asus X58 Sabertooth
