I hate DDCs from experience as I have had TONS of them die on me but never had a D5 die. I have a graveyard of them and a :banana::banana::banana::banana:load of tops (XSPC dual pump tops included).
U hater :rofl:
http://2.bp.blogspot.com/_mmBw3uzPnJ...na_Hate_05.jpg
This actually looks pretty good, i remember seeing a similar mod here on XS few years back, only gripe is this would be the only Koolance part in my rig and I'm not really a fan of Koolance.
Would you believe me if i told you I've had mine since 2007 purchased from FrozenCPU and still runs perfectly fine with hardly any noise.
Edit: can't stop visualizing how this would look in my rig with modded top, EK you reading this lolz.
Well, we've known that heat sinks helped the DDC's since we started using them in 2006. Some of our early high ambient bench units got the RAM heat sink treatment.
I'm also aware other members like Bei and Naekuh did very nice, specialized DDC heat sinks before us, so respect, mon.
With more temperature complaints from customers lately on the DDC, we decided to offer something ourselves. It does involve removing the stock plastic base entirely, and it is a little technical to assemble (nothing you guys can't handle, but maybe a little complex for others). Best of all, it does help with temps.
No argument from me that D-5 does run cooler and tends to have a higher reliability rate. But you can't fit a D-5 in a single 5.25" bay, either.
Tim
Quick question for Koolance, I use the PMP400 with the top and res and the bracket screws into the two extra holes on the bottom of the pump, how do you attach the bracket to the heat sink?
sniff sniff....*reaches into drawer and pulls out his trusty stainless Kimber Raptor II and places his lips over the end of the barrel*....."Hmmmm let's see if I can suck all the bullets out!" :rofl:
But seriously though that Koolance setup is sexy and I would go that route if I had a DDC I wanted to use.
It doesn't fit the bracket that comes with the COV-RP400 pump cover directly. We're going to have to note that and make something that will work. The mounting holes on the bracket correspond with the two hole positions on the PMP-400, but those are different than the new standoffs we provide on the HTS-PMP400 heat sink.
For now, you could match one of those standoff holes with the bracket to mount it. The bracket goes underneath the heat sink, so it will still support the weight (upside-down picture below). Or, you could drill new screw holes through the existing bracket which align with a couple of the heat sink standoffs. There's also threaded holes on opposite sides of the HTS-PMP400 metal base that could be useful.
Tim
Just so it's on record, I created Microsoft, but Bill Gates locked me in his basement and no one believes me!
ive had mine since 08 and its still going strong and its always had an ek v1 g3/8" top and a fan on it
but now that i said something it will die and i will have to get some jegway or whatever the cpx pro or ocz or ek is and as the d5 is a waste of space
why is it $35 that seams a little much
Why, all we'd see is flash rebound. :p::rofl:
NaeKuhsaywhaaaat? I have one on the way. . .well, it has to actually get to P-PC's first,:rofl: "should" show up sometime on Friday from the email I got from them. Seems they weren't expecting anyone to order them the night they went up on the site so I actually wound up pre-ordering it. :brick:
For all the D5 deniers: my D4 (four) pump, from around 2005, continues to provide the pumping goodness to my backup computer.
No conflict with a reservoir and top attachment. We include shorter and longer mounting screws to mount the pump up into whatever.
Here's something important. There are two cutout areas below the HTS-PMP400 metal body designed to avoid the DDC's power wire solder points. Our initial web pictures had this oriented the wrong way, which might short a pump if its solder points are especially thick. This is the corrected picture now on our website:
http://www.koolance.com/water-coolin...-pmp400_p2.jpg
If you receive one of the first HTS-PMP400 units, the assembly diagram shows "insulation tape" to place over those solder points. But the bracket cutouts were added before release, so the tape was no longer needed. (This isn't to be confused with the small piece of heat shrink we currently include for the pump wire, which is completely optional.)
Tim: how much wider is the Koolance cooler than the original pump dimensions?
Koolance,
Will your PMP-400 heatsink simply bolt on to a Swiftech MCR355?
Thanks,
