Its a public download over at BT too Thanh ;)
Bugfix version up on my site, check the OP for Download details :)
RPC error on disabling services now working,
Win32 version now under Dev by ARO, ill get to it as well when im back from holidays ;)
After disabling services and running 3dvantage I get a COM+ error, is this a common issue?
Disabling services using this program and running 3D = EPICLY bad idea,
I can create a separate program to do 3D tweaks if there is a demand?
Yes please! :D I know your program worked pretty well on giving me an edge in wprime :)
Ill get to it when i get home from holidays, will need some testing work too so gimmie 2/3 days and ill have it done :)
Have been thinking of developing a 3D app, the same as this, but with only 3D specific functions and will only disable services & change reg keys that will allow 3D benches to work,
Would anyone be interested in such an app and if so, name the features you would like to see in it and ill see what I can do!
And if you haven't already, don't forget to download the Benchtec Toolbox Bug-fix V1.4.2 from my sig ;)
And thank you for all of you who have,
Today the Toolbox broke through 750 downloads! Lets get to 1000!
D/L link now fixed, sorry about that guys, major site overhaul and i forgot to update my links :$
All should be well now, I WILL get back to working on this/the 3D version soon, too busy with work/guitar at the moment :)
New version v1.5 up
Adds:
PCM05 - Transparency disable/enable tweak
Screenshot - Save to dialogue to allow you to have them taken to a specific location
Fix - On Wazza the dialogues when Stabilization period was selected were in a strange order, now working okay
Will get working on the NVidia GTX4XX LOD ASAP too...
I have a feeling it will be in the 3D tweaking application :)
If anyone has tweaks they know of for 3D please post them here and I shall try and integrate them :)
Enjoy!
Myles
V1.5.1 Available for Download!
Changes in this version:
Added - Checkbox to change ALL other processes to low priority
Added - Ability to set custom CDT file size
Changed - Link on BTUK Logo
To-Do - Add submission to HWBot API
To-Do - Add ability to change LOD for GTX4xx Series & V2xx.xx Drivers
Happy benching!
Myles
