I heard, that scores will be around 50k :rolleyes:
Hmmm not sure yet won't know until i scale up cards to see how much clocks do for them.
Testing cpu scaling now.
disabled sli single
http://chew.ln2cooling.com/qdig-file...x480/lrg_1.jpg
enabled sli 3 way
http://chew.ln2cooling.com/qdig-file...x480/lrg_2.jpg
disabled sli single
http://chew.ln2cooling.com/qdig-file...x480/lrg_3.jpg
enabled sli 3 way
http://chew.ln2cooling.com/qdig-file...x480/lrg_4.jpg
I may have to redo single card results......something is buggy.
looks like the Pci-express slots changed from 2.0 down to 1.0.
Ok preety interesting, it's certainly scaling preety good. Be interesting to see if 4th card continues scaling.
Don't mind the cpu clocks........its hot and this cpu is a turd other than the imc but only one i had freed up atm.
Single 03 with cpu OC.
http://chew.ln2cooling.com/qdig-file...x480/lrg_5.jpg
3way with cpu OC
http://chew.ln2cooling.com/qdig-file...x480/lrg_6.jpg
3way with higher cpu + gpu OC
http://chew.ln2cooling.com/qdig-file...x480/lrg_7.jpg
single vantage cpu OC
http://chew.ln2cooling.com/qdig-file...x480/lrg_8.jpg
3way vantage cpu OC
http://chew.ln2cooling.com/qdig-file...x480/lrg_9.jpg
3way vantage cpu + gpu OC
http://chew.ln2cooling.com/qdig-file...480/lrg_10.jpg
Awesome.
I wonder what four card scaling will be like. I see your using your GTX2 there, nice ram clocks.
ufff, how do u made it?:)
Told you it worked bloody good :D
So finally sourced a 4 way SLI adapter and sadly it doesn't work or at least work right.
SLI .cfg shows 2 seperate dual sli .cfgs.
well, chew, I think if you could contact with Tin_EOF, maybe you both may do something with it or at least try run 4way on non-dual-nf200 board ;)
4way tried on "love-board" or msi/gb ud7 ? (answer via pm if you want ;) )
so andre-yang-classfield-x58-style-right ? ;)
I think if the software to hacks the drivers could tell the drivers that the motherboard used is EVGA E762 or GIGABYTE X58A-UD9 or SR-2 :rolleyes: maybe it would work. any way waiting for 3way sli + cpu subzero cooled amd rig :D that's what we want see chew :D any news about it ? :D
so we're waiting ;)
well, any updates ?
great hack
We are gonna run this rig once again. This time live at quake con on ln2 gents :) My crystal ball says somewhere in 38-39K range if cards are left on air.
And maybe atacking 7 GHz now?:)
to find a 7 gig chip would require oh i dunno binning well over 100 chips? There are 4 7 gig chips in the world. 2 madd owns.
If i were you I would ask madd how many chips he tested just to find those chips that are way out there ;)
Still using the 5 chips which is now down to 4 that i had from the beginning although tested 2 week 21's since then which are nothing special.
For me binning excessively is misleading. It also takes some of the fun out of it for me and for others.......could i bin lots of chips and have a frequency advantage over everyone? sure.....would it be fun anymore? no, i would get lazy and not tune for performance ;)
The Win7 0.8 x64 SLIPatch: http://www.techpowerup.com/forums/sh....php?p=1912614 If anyone is interested in trying. Hell, I may buy a couple of GTX460 1GBs now.
hm, u have right with this....I have 2 chips 1090T BE and between this is 200MHz diference....
