Väldigt fina färger på sleevingen :D
Cool that you're following the Simplicity!
The pump is indeed a 2.2 but the fans are Xigmateks.
Yeah I sand everything and prepare them very neatly, that's the key to a good result.
We have the same vision! ;)
Thanks man, always got love over for subscribers. :up:
Thanks bro!
It just takes a lot more planning. :)
Indeed they are.
This is my black box, the central point for all the electrics to meet up.
It will deliver power to the pump, my three fans and a SSD/HDD.
http://img685.imageshack.us/img685/2223/46876243.jpg
http://img828.imageshack.us/img828/7181/90664646.jpg
http://img839.imageshack.us/img839/2306/95931309.jpg
http://img836.imageshack.us/img836/898/87737601.jpg
http://img839.imageshack.us/img839/5766/87967547.jpg
Not a lot of movement on here, haha!
Made a fan-pump splitter to place inside of the black box.
http://img843.imageshack.us/img843/5067/16504161.jpg
http://img841.imageshack.us/img841/1026/81179382.jpg
http://img843.imageshack.us/img843/1812/13990177.jpg
http://img839.imageshack.us/img839/5966/74047836.jpg
http://img834.imageshack.us/img834/9151/ecosleeving.jpg
If it was green sleeving it would have actually taken me a while to notice it between the leafs :p:. Nice job on the sleeving and love the black box :D.
is that a lian li psu cover i see there :D
awesome idea though!
and when do we get to see inside the black box?? The fan splitters is awesome, looks like it was a PITA though. How do you like the shrink tubing on your 3rd hand? Does it help?
Laine "ECO" :)
great photos and build :up:
Yeah I had that idea too, but it would look too out of place once in the build.
Thanks man!
It is, yes. :)
Thanks!
Well, it's the fan-tree, the sata that goes out the top, and then this PCI-E splitter. :)
It was the biggest PITA ever, and the 3d hand with the shrink works like a charm. :up:
Haha, yeah! Thanks.
I present to you, the legen-.. wait for it.. -dary PCI-E 6pin splitter that will be located inside the black box. It's still missing a large heatshrink to cover the splices.
The PSU was modded to fit a 5770, but as I'm stepping up to a GTX460, I had to make this. :D
http://img35.imageshack.us/img35/9987/48426989.jpg
http://img191.imageshack.us/img191/7482/23425045.jpg
http://img713.imageshack.us/img713/938/12899803.jpg
http://img14.imageshack.us/img14/2366/42737098.jpg
http://img23.imageshack.us/img23/7177/57196201.jpg
The photos may differ, and I'm sorry for that but I'm on a old laptop far away from home, using a borrowed D40, and I'm no Nikon-guy.
I love 'em bro!
Dam dude extraodinary sleeving skills, u should see my work its shocking!
Thanks bro!
Thanks man!
This I'm damn proud of, finished my black box exactly how I wanted it. And I love it!
The fans will be connected through the holes on one of the sides. :up:
http://img39.imageshack.us/img39/9905/54056509.jpg
http://img130.imageshack.us/img130/9415/57331625.jpg
http://img841.imageshack.us/img841/9756/61102194.jpg
http://img808.imageshack.us/img808/8116/51889642.jpg
http://img833.imageshack.us/img833/5844/54399906.jpg
http://img834.imageshack.us/img834/3595/90867125.jpg
http://img43.imageshack.us/img43/4852/27458145.jpg
Looks like candy! I want it :eek:!
Wow man the attention to detail is crazy good. Cant wait for the finished project.
holy :banana::banana::banana::banana: laine. I love every one of your builds.
Beautiful build. So class!
Thanks man!
And I love people that like my builds! :)
Thanks!
I finally got my parts, so that I could mount my other radiator. :up:
Also got a ram block, will have to cut the fans to make space for a fitting, going to be fun.
http://img185.imageshack.us/img185/6517/27142418.jpg
http://img638.imageshack.us/img638/1282/44707203.jpg
http://img267.imageshack.us/img267/3290/60227495.jpg
http://img3.imageshack.us/img3/2365/12405431.jpg
http://img835.imageshack.us/img835/4730/28071567.jpg
http://img148.imageshack.us/img148/5227/13514027.jpg
http://img835.imageshack.us/img835/6254/40452185.jpg
http://img96.imageshack.us/img96/9505/29874215.jpg
lookin' good fellow,
good luck with the tubbing management though ;)
are you intending to let it seen through a plexi or something?
Loving it :) As usual.
Thanks man!
I'll let the other plans bea secret for now.
Thanks!
Made an adapter for the power supply, and test fitted the reservoir.
The liquid turned out great. :up:
http://img189.imageshack.us/img189/4097/28421684.jpg
http://img713.imageshack.us/img713/7447/45201262.jpg
http://img412.imageshack.us/img412/2113/35577672.jpg
http://img818.imageshack.us/img818/5398/82201117.jpg
http://img716.imageshack.us/img716/1245/22776067.jpg
http://img12.imageshack.us/img12/64/37716591.jpg
http://img708.imageshack.us/img708/2666/29929440.jpg
http://img828.imageshack.us/img828/7342/92013948.jpg
Looks amazing so far, good work!
I really love that colour for the liquid. Incredible job on the PSU adapter, you have nice skills for every task you do, I'm jealous :P
this is superb, i have looked at this case a lot recently, never thought you would be able to stick all of that in there!
Thanks Whiteroom!
Yeah the purple is lovely. The psu bracket was just a test version, will make the real one out of stainless steel. :)
Thank you!
Lovely case to work with though, top and bottom is removable, the case walls splits in two L-shapes.
Because of the small size of the case, my ram block and fittings hit the fan and barely missed the radiator.
Today I finally went ahead and made something about it, turned out really good imo.
http://img708.imageshack.us/img708/3055/75939973.jpg
http://img814.imageshack.us/img814/8179/84849086.jpg
http://img844.imageshack.us/img844/9620/89308139.jpg
http://img411.imageshack.us/img411/1153/33049174.jpg
http://img442.imageshack.us/img442/8641/24400071.jpg
http://img706.imageshack.us/img706/4219/13643153.jpg
http://img840.imageshack.us/img840/6971/20592449.jpg
http://img80.imageshack.us/img80/426/53885868.jpg
You can't stop surprising me. That job on the fans to let the fitting go through it's nearly perfect, I've never seen anything similar to that.
You have inspired me to change my ATX board rig for a MicroATX to try something on a smaller case because I'm tired of big cases but I really "need" Sound Card and I want to use mi i7 920 so the only way it's to use MicroATX and maybe I will try on the future V354.
Keep on working, this is going to be one of the best SFF builds for sure.
that's one sweet option you got there! :up: mate!
