You can try asking around on the my digital life forums but you may not get much help. You basically just have to sniff around posts there and eventually you will find O-ROMs of all sorts.
Yeah, I've done this already... lol
I guess they just find out accidentally, when a BIOS contains a new O-ROM and extract it then.
Other question: I modified the P5Q-BIOS for practice with Rampage Formula 1001 P6 table and memory table, Intel SATA RAID ROM 9.6.0.1014, Marvell 88SE6121 Option ROM 1.1.0.L73 (like your modified BIOS for P5Q), but the BIOS I created is not exactly the same as yours. I made the same modification a few times and every time there is a slight difference between the BIOS-files, so I think everything is okay , but would you have a look at my BIOS?
Here it is: http://rapidshare.com/files/413918119/for_Ket.7z
Anybody know if it's possible to mod a gigabyte p55a ud3 bios?
Thank you, mr. BIOS! Your P5Q mBIOS thread aroused my interest in BIOS modding. :up:
If I ever find new O-ROMs or tools, I will post them here.
:up: Much appreciated! Anybody know which module ID in AMI BIOSes built for AMD platforms is for supported memory? Can't find any info anywhere.
I've got a Asrock 890FX Deluxe3 BIOS I been working on. At this time its as tweaked as I can make it. The main strength in this BIOS is to provide much better CPU support and increase FSB and CPU-NB clocking.
Default BIOS: Max bootable FSB 290, max bootable NB frequency 2970.
Tweaked BIOS: Max bootable FSB 302+, max bootable NB frequency 3060+
Of course I can't guarantee everybody will benefit from this BIOS but for me its working well so far. When I can figure out how I'll also be looking to greatly enhance the Deluxe3s memory compatibility. So, whos interested in trying this BIOS?
So, dude, are you done with tweaking maximus 2 formula Bios?? I know that it's not your main rig right now, but if you need a beta tester of the M2F bios, you can count on me ok?
Have a nice day ket!!
There won't be any further tweaks for the M2F. Its as good as its going to be.
I have a request! :)
I have a Foxconn nt-330i that gives no option to disable/enable hyperthreading or to change Sata Mode Operation from IDE to AHCI, and vice versa. These are really the only two changes I need to successfully complete me hackintosh build :D, though any additional options such as overclocking or adjustment of fan speeds would of course be welcome. The current bios basically allows you to change almost nothing. If you need me to upload the bios, let me know. Thanks!
http://www.foxconnchannel.com/produc...30i/index.html
http://www.newegg.com/Product/Produc...82E16856119016
I've never dealt with a netbox BIOS before, I'd assume its not too different. I can only effectively do some mods for AMI BIOSes, nothing else as I either don't have all the tools or in the case of Award BIOSes no experience beyond unhiding options.
Hi, can you tell me what program you use to modify bios?
Being a netbox, I highly doubt theres anything hidden and normally I wouldn't take the risk. However if you want me to have a look give me a link and I will.
I appreciate it. Here is the bios download link:
http://www.foxconnchannel.com/driver...20943F1P06.zip
I have a MSI 870A Fuzion and it "feels" like the BIOS is really holding me back both when it comes to CPU and memory clocking, it's also pretty unstable in general when clocking and can be hell to boot (just like my MSI 790FX GD-70 before the BIOS matured).
MSI seems to have dropped to bomb on my motherboard since a newer version of it is out, care take a look? It's AMI BIOS.
http://www.msi.com/index.php?func=do...1&prod_no=2105
Any chance you could take a look at the Biostar TA890GXB HD BIOS? It's an AMI BIOS and is fairly limited as to the options included. I'm using it as a low power server w/ a 45W CPU and would ideally like to undervolt the CPU. The BIOS only provides options to increase the voltage. I'd also like the option to turn on IOMMU if possible. You can download the BIOS here:
http://www.biostar.com.tw/app/en/mb/bios.php?S_ID=478
Thanks!!
Can anybody upload the last mBIOS (2302) please?
I'd would appreciate it a lot!
Thank you very much and have a nice day!
Hello guys, if you have a copy of the bios on the disk and you can put me anywhere I would be very grateful
