yes, stable at 260 and 1.67 and 262 at 1.75Quote:
Originally posted by C0bra
Marvin: Is that stable? and water cooling?
that is the limit.
that is the limit.
My normal 2.8 can only do 3.3@1.8Vc:(:(:(, i hate it, i whould get close to the 9600PRO 2k1 record w/ a good CPU.
I will have a chiller in like three days, but my mobo is gone at RMA so i will only test it in one week(around that). I will try if 1.9Vc will help(op so).
But some CPU are very good, other to the average, and other poors. Guest im in poor categorie
I got my 2.8 M0 today:YIPPIE: and im testing it now.. so far i have only tried 230fsb, and it runs prime flawless@stock vcore :banana:
It did 240fsb @stock vcore, but locked after 5mins of prime @ 250fsb and stock vcore..
255fsb@1.6vcore ran fine, but i got reboot after 30sek when i tried 260fsb@1.6v.. running it at 260fsb with 1.65vcore now.. It's getting a bit hot!(47c after 5min with prime..) Cause i havent botherd removing my old goop from my block( have used the goop over 5times..) and i just took some quickley on mye cpu, im going to lap it later this week so i just intended to test it now..
my p4 sl6z3 2.4, does 3.3 vcore stock rock solid, primeable....
255 is stable@1.6vcore but 260 aint even stable@1.65vcore.. I think it's my temp..
Nice I can get my 2.8c (SLW) to 250FSB Prime Stable @ 1.6 VCore with simple air cooling ;)
WOW. My can only get 236@1.7...LOL
mine does 250 at stock voltage
I could get 3599 @ 1.6v with my slk900 not prime but 3d stable. Can't attach a pic I don't have the option.
Anyone tried Enabling the L3 cache with CPU MSR ?
:slobber: :eek: Wow, this is very interesting :DQuote:
Maci what is this program I just downloaded lol ?
It says its only for power users only... does that mean extreme enthusiets only or something?
And can you explain this prog please, I don't want to ยงยงยงยง anything up ya know. Oh yea did you unlock the L3 cache with it as well? (SLZ only I see :()
Just run it and you will see. But do not change any parameters :P
Well I did run it... it doesnt really do anything at all.
And what the hell is On Demand Clock modulation?
that looks like a kind of DOT(dynamic overclocking technologie) that MSI have on there board
Actually I did. It seems to do nothing or I actually can't figure out how to make it work myself.Quote:
If I disable L3 cache on my EE the system will reboot instantly.
Same here :(Quote:
Well, we don't have it and we want to enable it.Quote:
You have it and are trying to disable it. Which is VERY strange why you even tried to do that anyway......!
Therefore, you don't count.:p:
Does it just enable L3 cache? Can i mess up something?Quote:
I dont work;)
Paste up some screenshots with all available functions :P
OFF TOPIC: is L321B407 a good deal?
