I hope they add atleast a drop-in fan filter for front door. Also, wouldn't there be 2 CPU cut outs in the mobo tray if it is going to support these dual socket boards?
Hmmm, not bad. Still waiting on LianLi to bring inverted ATX back though :(
What I need is a nice, sleek, Lian-Li style AL case with an inverted motherboard tray that can fit my SR-2. Seems like I have to go custom eh...
mh not bad.
but I would like to have another psu spot at the top (ok tower will be even larger) + the old style of the v2000....I don't like the design after the v2000 at all.
hope they release at least 2 versions of it, like before, because that door....nty
The case opens on the wrong side!
Hi,
any word on availability dates for these cases ?
Thanks.
yeahh.. availability and price info??? is it going to be in the 350$ like any other high end lian li ????
New info (Final Specs actually i guess) (EDIT: Err, any way to input a table here ? tried the tags but don't seem to work)
http://www.lian-li.com/v2/en/product...ndex=61&g=spec
http://lian-li.com/v2/tw/product/upl...0/v2120-01.jpg
Model | PC-V2120
Case Type | Full Tower Chassis
Dimensions | (W) 235mm x (H) 635mm x (D) 630mm
Front bezel Material | Aluminum
Color | Black / Silver / All Black
Side Panel | Aluminum
Body Material | Aluminum
Net Weight | 14.4KG
5.25" drive bay (External) | 5
3.5" drive bay (External) | None
3.5" drive bay (Internal) | 10 + 3 (Use 5.25 x 3 Bays)
Expansion Slot | 11
Motherboard | ATX / M-ATX / HPTX
System Fan (Front) | 140mm Fan x 3
120mm Fan x 1
System Fan (Top) | 120mm Fan Hole x 3
System Fan (Rear) | 120mm Fan x 1
I/O Ports | USB3.0 x 4 / e-SATA x 1 / HD Audio
Maximum Video Card Size | 335mm
Some key features
Front 140mm Fan x 3
http://lian-li.com/v2/tw/product/upl.../v2120-19s.jpg
Removable M/B Tray
http://lian-li.com/v2/tw/product/upl.../v2120-35s.jpg
Top 3 x 120mm Fan Holes
http://lian-li.com/v2/tw/product/upl.../v2120-33s.jpg
11 x PCI Slots
http://lian-li.com/v2/tw/product/upl.../v2120-11s.jpg
2.5" HDD / SSD mounting kit
http://lian-li.com/v2/tw/product/upl.../v2120-29s.jpg
The rest is standard lian-li. Tool-less motherboard installation, USB 3.0 etc etc.
Colour's
PC-V2120B(Black)
PC-V2120A(Silver)
PC-V2120X(All Black) :clap:
Release date it seems is 2010/08/01, so i would assume a September-October region when it is available easily across major stores. Pricing still no clue.
Something on the V1020 also.
http://lian-li.com/v2/tw/product/upl...0/v1020-01.jpg
Model | PC-V1020
Case Type | Mid tower chassis
Dimensions | (W) 220mm x (H) 562mm x (D) 505mm
Color | Black / Silver / Red (Internal black)
Net Weight | 9.15KG
5.25" drive bay (External) | 3
3.5" drive bay (External) | 1 (Use one 5.25-inch to 3.5-inch converter)
3.5" drive bay (Internal) | 3.5-inch HDD x7 & 2.5-inch HDD x1
Expansion Slot | 8
System Fan (Front) | 140mm blue LED fan x 2 (PC-V2120A/B)
140mm red LED fan x 2 (PC-V2120R)
System Fan (Top) | 140mm fan x 1
System Fan (Rear) | 120mm fan x 1
PC-V1020B(Black)
PC-V1020A(Silver)
PC-V1020R(Red) / Internal black
Thanks toocooljonty
