raju
is the drmos (drivermosfets) not good for high power app? looking at the drivermosfets from asus..it looks beefier.
raju
No it is something else. I've told MSI, and it is what it is.
imc vreg?
wish i knew which hw shortcoming it had...hehehe
A7666IMS.10Z ---> A7666IMS.111
01. Follow PCB1.1 to add QPI VDroop Control Item.
02. Follow PCB1.1 to add DDR Phase Mode & LED Control.
03. Fix SLI function fail issue. (Fix N9600GT VGA Card S3 resume issue side effect)
04. Fix XMP Profile2 DRAM Frequency display error issue.
A7666IMS.111 ---> A7666IMS.112
01. Fix DDR Phase LED error when S3 resume issue.
02. Clear non VGA BIOS RAM to avoid other device option ROM invoke failed.
Mike.
weird Raju we didn't have any power issues with GT over 6Ghz... not with the early (modded) nor the retail sample (unmodded)... bios indeed needs some fixes...
What do you mean with the HW side is not that great ? Not enough gimmicks ?
Too many gimmicks, not enough substance IMO. There are areas where $200 boards can do better.
What if you put things in perspective? Can the flaws cause inferior overclocking results by a large margin?
I noticed BenchBros hit 6.6G aquamark (ok - no vantage, but still) and AndreYang 6.7G 3D.
So do you guys feel the asus rampage 3 is a better motherboard?
My friend got himself one today and seems there's a problem detecting his HDD's do you guys know which could be the problem? any response is greatly appreciated!
Thanks,
Blacky
For bloomfield 24/7 OC there's only REX III... my UD9 has big issues with booting over 220Bclock from bios, same counts for the Xpower (QPI issue)... For LN2 this is a very durable board and I was amased it blew my REX III sample away
I think you'll find it's far closer on the retail sample R3E now Leeghoofd. The R3E is a very well executed board.
A major issue I found was in USB speed.
If you try to install an OS via USB it will take forever.
Leeghoofd did you tested this mobo with a bloomfield CPU? if yes, what's the max BCLK with QPI in full and slow mode?
what about efficiency in 32m?
Did anyone get the OC panel, disks, sound card or manual? :rolleyes:
I think I may try this board. I need 215bclk for my 920, nothing more. The price is right, and it looks like it comes with a sound card. I thought about trying the REX III but I am not an Asus fan and dont want to pay 369.00 for one.
I got all in my media package Charles, though the Driver DVD (not a final release one) is fubarred, takes ages to read and can't install a darn thing from it (probably burned to fast)
Mafio : for Bclock we found with Bloomfield/GT that you can boot max from bios 220Bclock (QPI issue). When doing soft resets you can go up to whatever ya CPU can handle (my 950 is 229 max on 3 boards on air and LN2, crap CPU) Massman did 249 on GT with SlowMode. We already passed it to MSI so hopefully they will get this fixed as 220 is not good enough for a 2nd generation X58 high end board. I'm experiencing similar issues with the GB UD9 board. The REX III and Classie boot straight around 230Bclock :banana::banana::banana::banana: on air... which is how it should be...
I'm not into slow mode really... either it works flatout or it doesn't here... (I'm more the 3D guy for benching) REX III here did 238Bclock 3D06 stable, will need to get some LN2 to tests the Xpower and UD9. ( as my phase unit is dead )
I'm still busy digging into these boards, but below is the average result of a stock run on my 950 with rams at 1600Mhz C8-8-8-24 1T TRFC 88 and uncore at 3200Mhz. OS Win7 Pro 64bit
http://users.telenet.be/OAP/Xpower/Mafio.jpg
Need to rerun all the tests on the REX II for comparison (was benched on another OS a year ago). Just for Info : REX III Bios 704, GB UD9 on F4A and the MSI on 111 bios. I need to find out why the REX III was slower here as in most of the other tests it was king of the hill. Xpower seems good bang for the buck, UD9 is not so good in that department :p
thanks
efficiency is very good :yepp:
edit: maybe R3E is slower in 32m because of higher RTL
i don't know what kind of benchmark did you run but 32m depends a lot by memory and low RTL means easily 1 or 2 sec faster :shrug:
Could be, there's where the quests begins :) I usually run 3D01, 06, pi 1 & 32, Wprime32 & 1024, Cinebench, Pcmark05, X264HD, FarCry2 and RE Benchmark...
i don't know about pcmark but all the others test aren't that sensible to memory settings.
therefore higher RTL setted by default by R3E could be the reason of this gap in 32m.
comparisons between mobos are always tricky, there are to much things that can influence the results...
