X6 1090T @ 350x12.0, 4GB Memory @ 1400MHz CAS5, Post 1 Of 2
ASUS Crosshair IV Formula, 0905 BIOS
Phenom II X6 1090T
2x2GB Super Talent Speed Series (WS220UX4G8) PC3-17600 2200MHz 8-8-8-24
350x12.0, Memory @ 1400MHz 5-5-5-15
OCZ 100GB Vertex LE100
SAPPHIRE 4870x2, 4870 Trifire
Asus 5870 V2 - Used for both versions of CineBench
OCZ Z Series 850W
click for larger image
http://www.edgeofstability.com/image...os/main1_s.jpg http://www.edgeofstability.com/image...os/main2_s.jpg
http://www.edgeofstability.com/image...os/dram1_s.jpg http://www.edgeofstability.com/image...os/dram2_s.jpg
http://www.edgeofstability.com/image...advanced_s.jpg http://www.edgeofstability.com/image...os/north_s.jpg
Code:
Configure System Performance Settings
Target CPU Frequency:. 4200MHz
Target DRAM Frequency: 1400MHz
CPU Level Up......................[Auto]
OC Tuner Utility
AI Overclock Tuner ..................[Manual]
CPU Ratio............................[12.0]
CPB Control..........................[Disabled]
CPU Bus Frequency....................[350]
PCIE Frequency.......................[100]
DRAM Frequency.......................[1400MHz]
CPU/NB Frequency.....................[2800]
HT Link Speed........................[2800]
> DRAM Timing Configuration
> DRAM Driving Configuration
************* Please key in numbers directly! *************
Extreme OV...........................[Disabled]
CPU & NB Voltage Mode................[Manual]
CPU Voltage........................1.554 [1.521875]
CPU/NB Voltage.....................1.422 [1.375000]
CPU VDDA Voltage.....................2.560 [2.50000]
DRAM Voltage.........................1.726 [1.67500]
HT Voltage...........................1.336 [1.30000]
NB Voltage...........................1.283 [1.25000]
NB 1.8V Voltage......................1.802 [1.802000]
SB Voltage...........................1.111 [1.113000]
VDDR Voltage.........................1.205 [1.205750]
VDDPCIE..............................1.113 [1.113000]
DRAM CTRL REF Voltage................0.500 [0.500]
DRAM DATA REF Voltage................0.500 [0.500]
CPU Load-Line Calibration............[Enabled]
CPU/NB Load-Line Calibration.........[Enabled]
CPU Spread Spectrum..................[Disabled]
PCIE Spread Spectrum.................[Disabled]
DRAM CAS# Latency....................5 [5 CLK]
DRAM RAS# to CAS# Delay..............5 [5 CLK]
DRAM RAS# PRE Time...................5 [5 CLK]
DRAM RAS# ACT Time..................15 [15 CLK]
DRAM READ to PRE Time................4 [Auto]
DRAM Row Cycle Time.................20 [20 CLK]
DRAM WRITE Recovery Time.............6 [Auto]
DRAM RAS# to RAS# Delay..............4 [Auto]
DRAM READ To WRITE Delay.............6 [Auto]
DRAM WRITE To READ Delay(DD).........2 [Auto]
DRAM WRITE To READ Delay(SD).........6 [Auto]
DRAM WRITE To WRITE Timing...........4 [Auto]
DRAM READ To READ Timing.............3 [Auto]
DRAM REF Cycle Time................110 [110ns]
DRAM Refresh Rate..................7.8 [Auto]
DRAM Command Rate...................1T [1T]
DCTO Information:
CKE drive strength................1.5X [Auto]
CS/ODT drive strength.............1.5X [Auto]
ADDR/CMD drive strength...........1.5X [Auto]
MEMCLK drive strength.............1.5X [Auto]
Data drive strength................1.X [Auto]
DQS drive strength.................1.X [Auto]
Processor ODT...................60ohms [Auto]
DCTO Information:
CPU Configuration
AGESA Version 3.7.0.1
AMD Phenom(tm) II X6 1090T Processor
Revision: E0
Cache L1: 768KB
Cache L2: 3072KB
Cache L3: 6MB
Speed : 4200MHz
uCode Patch Level: 0x10000BF
Microcode Updation..................[Enabled]
Secure Virtual Machine Mode.........[Enabled]
Cool'n'Quite........................[Disabled]
C1E Support.........................[Disabled]
ASUS Core Unlocker..................[Disabled]
CPU Core Activation.................[Auto]
DRAM Controller Configuration
Channel Interleaving................[Auto]
MemClk Tristate C3/ATLVID...........[Disabled]
Memory Hole Remapping...............[Enabled]
DCT Unganged Mode...................[Always]
Power Down Enable...................[Disabled]
http://www.edgeofstability.com/image.../350_lin_s.jpg
http://www.edgeofstability.com/image.../350_mem_s.jpg
http://www.edgeofstability.com/image...7/350_true.jpg
Code:
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 94.71 fps, 3898.70 kb/s
encoded 1442 frames, 94.61 fps, 3898.70 kb/s
encoded 1442 frames, 39.57 fps, 3962.08 kb/s
encoded 1442 frames, 39.64 fps, 3971.52 kb/s
encoded 1442 frames, 39.67 fps, 3953.40 kb/s
encoded 1442 frames, 39.77 fps, 3971.71 kb/s
System Details
Name AMD K10
product System Product Name
Codename
Specification AMD Phenom(tm) II X6 1090T Processor
Core Stepping
Core Speed 4200.3 MHz
Northbridge ATI ID5A11 rev. 02
Southbridge ATI SB750 rev. 40
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Command Rate (CR) 1T
Memory Frequency 700.1 MHz (1:2)
Memory Type DDR3
Memory Size 4080 MBytes
Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of processors 1
Number of threads 6
Number of threads 6 (max 6)
L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature 0 47°C (116°F) [0x2F] (TMPIN0)
Temperature 1 34°C (93°F) [0x22] (TMPIN1)
Temperature 0 39°C (101°F) [0x134] (Core #0)
Temperature 1 38°C (100°F) [0x130] (Core #1)
Temperature 2 38°C (99°F) [0x12C] (Core #2)
Temperature 3 37°C (98°F) [0x129] (Core #3)
Temperature 4 37°C (97°F) [0x125] (Core #4)
Temperature 5 37°C (98°F) [0x128] (Core #5)
whau, next setings benchmarked :-). Good work Praz!
nice work praz. does 4.2ghz need that much vcore? or did you just throw something at it to know it would be stable?
he is on air too. Most thubans on air are stable between 4100-4200MHz
Thanks guys. 4200MHz is about the limit on this CPU for 24/7 because of the voltage required. I'm running it now at 4085MHz with 8GB of memory and the voltage is set to 1.43V in the BIOS. Quite a difference for a little over 100MHz clock speed.
yes, 4083 and 1.43V is great choice for longtime stable using
