thanks :toast:
im on 64bit tho... let me see if i can find the 64bit one...
thanks :toast:
i downloaded the latest verde driver... but it tells me its not compatible with my laptop :rolleyes:
lol in my lappy works fine saaya
check if you are running the hd or the g210
This tool would not let me adjust core speed (EVGA 480 SC) all other features seemed to be accessible.
Anyone find a driver that doesn't have the 1.125 limitation on voltage? Some shots have it up to 1.2, but I'm stuck at 1.125.
wtf, really? idk man... it tells me setup couldnt detect any compatible gpu... and yes, i switched to nv graphics, of course...
bah, i should have gone for the model without nvidia gpu, only used it for 6 hours or so since i bought the laptop... :rolleyes: :D
any1 know whether the 1.138 V on gtx 480 is software limited or hardware?
Software. You can get 1.21V max. Here's my card running the latest BIOS modded by Oliver. Check out the 470/480 thread in nVidia forums.
http://img43.imageshack.us/img43/958/121vgtx.jpg
Found a replacement for Afterburner! :)
Good job mate.
nice job :)
Nice tool but is there profiles ?
Nice little tool, immediately blue screened my laptop though. Works fine after upgrading to 196.17 drivers.
This tool would be perfect if it would auto-apply clocks at startup.. :)
Nice tool, I like. :up:
On my Giga 260gtx SLI setup I cannot adjust voltage. But using Afterburner I can, or maybe it just looks like I can.
nice tool :)
I get this error on my 9600GT:
http://i145.photobucket.com/albums/r...aToolError.png
I run an HD4870+9600GT(PhysX) setup.
Version 1.82:
- new method to retrieve shader count
- simple profile management through command line parameters
out now! ;-)
