Originally Posted by
flashnc
On my EVGA 470... I didnt have the over excessive amount of TIM...I was kinda suprized. It actually looked like it was put on with some concern ( though I know it wasnt ).
But, what I have noticed, on mine anyways, is the main part of the cooler on the die* isnt very flat/smooth at all...even though it is a direct contact** it is very uneven, grooved ** and also, the screws that hold it in contact, will only go down as far as the stop* not allowing a very solid pressure...I can after tightening as far as it will allow, still easily move the cooler by rotating it...
I plan on later today adding ( need to see if the screws can be removed, I havent checked yet , but im sure they can be) some small washers under the screw heads to apply a more positive* solid pressure... after applying AC5 Im still not really seeing anything substantial as far as better cooling ...** maybe 1-2 c on load...about the same at idle...
whoever first comes out with a really good solid** base cooler that is flat and polished** will sell them like cupcakes at a fat kids party**
